20 Most Recent Viking DMOC205 Microwave Oven Questions & Answers
ALl the functions continue to
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
2/25/2011 3:45:28 PM • Viking DMOC205... • Answered on Feb 25, 2011
Microwave oven stopped heating. However,
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dgdj
9/30/2010 2:36:14 PM • Viking DMOC205... • Answered on Sep 30, 2010
Turntable does not rotate
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
8/18/2010 3:36:51 PM • Viking DMOC205... • Answered on Aug 18, 2010
2answers
FUSE BLOWS ON VIKING VMOS MICROWAVE WHEN YOU SHUT THE DOOR
Could be shorted wiring in the door interlock
12/7/2020 4:19:41 PM • Viking Microwave... • Answered on Dec 07, 2020
I have a Viking Microwave that went complete dead a split second after I turned it on
1. Open internal fuse 2. Magnetron failure 3. Control board failure 4. Door interlock failure
12/7/2020 3:26:10 PM • Viking Microwave... • Answered on Dec 07, 2020
Viking vmor205ss Micro / convection oven combo Works but does not heat anything in microwave - Got a Magnatron - still no heat Got a new high capacitor & Diode - still no heat Got all new switches and fuse - still no heat - transformer ??
Might be the transformer or the control circuit that pulses the supply to the transformer at various rates depending on the power setting selected. I would suggest you first check the transformer is receiving a good supply before you spend more money. Beware of the transformer secondary that, if it is working, produces a dangerously high voltage (typically 2 - 3000 volts) that is far beyond the capability of most multimeters.
7/21/2020 6:12:18 AM • Viking Microwave... • Answered on Jul 21, 2020
Viking D3 micro model RDMOR200SST door button stuck in open position. What now?
Contact a microwave specialist to assess the problem!
5/31/2020 6:52:36 PM • Viking Microwave... • Answered on May 31, 2020
Why my Viking microwave doesn't make the sound when cooking is done?
https://www.youtube.com/watch?v=_CtGVScF0sU
3/6/2020 5:07:32 PM • Viking Microwave... • Answered on Mar 06, 2020
My viking microwave is stuck on half temp. I can't set it to hi. model #vmoc205ss
I would need more information to help you. Please e-mail me through my Web site with your full model number and detailed symptoms. Ed Miller http://www.microwavecontrol.com
12/15/2018 10:51:29 PM • Viking Microwave... • Answered on Dec 15, 2018
Viking VMO200 does not microwavecook. The unit light, cooking countdown timer, clock, and panel all work. What do you think? thank you
it could be a diode a cap a switch a fuse or your magnetron you can test it by your self with avo meter good luck
6/20/2018 7:39:19 PM • Viking Microwave... • Answered on Jun 20, 2018
MY 27 INCH VIKING PROFESSIONAL BUILT IN MICROWAVE OVEN ALLOWS ME TO SET THE TIME, BUT JUST COUNTS DOWN SILENTLY INSTEAD OF MICROWAVING WHEN PUSH START. CAN THIS BE REPAIRED? OR IS THERE A RESET?
Your bottom door switch is probably defective, or its mount is loose, misaligned, or broken. This is usually caused by opening the door while it's cooking (instead of hitting "stop" first) or slamming the door. See my help files on safety here, disassembly here, and door switches here. More questions? Contact me directly here.* * always include the full model number and FCC ID number from the label on / in your microwave (or a clear photo of the tag)
1/28/2018 10:24:08 PM • Viking Microwave... • Answered on Jan 28, 2018
Viking DMOC205 Microwave Oven Logo
8 questions posted
Top Viking Microwave Ovens Experts
NOEL
NOEL
Ngoro
john h
Are you a Viking Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Viking Microwave Ovens
Most Popular Question
all functions continue
  • Microwave Ovens
