20 Most Recent Maytag Amana 30 in. Electric Double Wall Oven with Temp-Assure Cooking System Questions & Answers
Service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Maytag Amana 30... | Answered on Feb 01, 2016
I use 2 sided tape to get a grip on the bulb. If it is really stuck and you end up breaking it, don't worry as it will be easier to remove the rest of the bulb with a pair of needle nose pliers.
Maytag Amana 30... | Answered on Nov 24, 2011
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Maytag Amana 30... | Answered on Sep 22, 2010
Localwonder gave a more comprehensive answer, but I wanted to share my recent related experience too:
Same model: MGR5750BDW
Oven was not heating up, or would sometimes and not others. Broiler worked fine. The nice thing is that the broiler igniter and the oven igniter are the same part. So I swapped them until I could get a replacement part.
Before I did anything, I turned off the gas!
To take out the broiler igniter: there's one screw right near the front of the oven that holds the burner assembly in place. Remove that, gently pull the assembly off the gas nozzle off to the left. Then where the wires from the igniter go into the back wall, remove the screw that holds the little door, remove that little door, and then gently pull the wires through until the connector comes through the opening. I also found you can go behind the stove, remove the back panel (which is easy) and see the igniter's connector.
The oven one: remove the floor of the oven by lifting it at the back, and then lift it out towards the back of the oven. Then you can see the igniter at the back of the floor of the oven. remove the two mounting screws, and then gently pull the wires until the connector comes through the insulation.
The bad igniter looked like it had burned down to bare metal in a big patch...not sure if that's the actual problem, but in any event, I installed the good igniter in the bottom (gently pushing the reconnected connector through the insulation, and feeding as much of the wires down in there as well), and the bad igniter in the broiler position (since that was the easiest one to access and replace, it'll be easy enough to replace when I get the parts). Tested, and everything worked great. And I could watch the bad igniter light up, and never light, confirming that it was the igniter itself that was the problem.
The best part, for this stove anyway, -- the ONLY tool needed was a #2 phillips screwdriver. Really. All told, maybe an hour of work, nothing intense. And free -- so if they both worked, it would have spared me ordering a part that didn't need to be replaced!
Maytag Amana 30... | Answered on Jul 11, 2010
the ignitor is prolly bad (not pulling enough amps)
Maytag Amana 30... | Answered on Dec 24, 2008
if voltage to transformer see if after to board if ok bad board if no bad transformer
Maytag Ovens | Answered on Apr 30, 2019
Usually a failing capacitor on the board to the display.
Maytag Ovens | Answered on Mar 03, 2019
You either have a bad control board or the touch pad has a button sticking and it needs the touch pad. The temperature sensor would not be a problem for this concern. I hope this helps.
Maytag Ovens | Answered on Feb 19, 2019
Either a bad connection or the motherboard wasn't the problem.
Maytag Ovens | Answered on Feb 18, 2019
Just a guess but the igniter may be defective even though new
Maytag Ovens | Answered on Jan 19, 2019
Hi Janine.
F3 means "Shorted oven temperature sensor" and it is returned when the oven electronic control detects a wrong impedance value from the oven temperature sensor circuit.
The oven temperature sensor is a probe located inside the oven cavity. The sensor can be removed from the oven and tested using a multimeter set on impedance. The impedance reading across the two sensor's contacts at room temperature must be about 1100 Ohms. Impedance increment rate is 100 Ohms more for every 50 degrees temperature increase. If the reading is sensibly different from this value the sensor must be replaced.
Here the replacement part:
Long Oven Sensor Kit
The sensor is indicated as part number 11 in the exploded view available here.
The sensor is held by two screws. In order to replace the sensor disconnect power, disconnect the connector attached to the sensor, undo the two screws and remove the sensor. Perform operations in reverse order to install the new sensor.
Regards.
Ginko
Maytag Ovens | Answered on Dec 27, 2018
Maytag Amana 30 in. Electric Double Wall Oven with Temp-Assure Cooking System Logo
14 questions posted
Top Maytag Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
View Most Popular
Maytag Ovens
  • Maytag Ovens
Most Popular Question
oven light
  • Ovens
