20 Most Recent
Frigidaire 26.0 cu. ft. Side-By-Side Refrigerator with PureSource 2 Water Filtration Questions & Answers
The water part of the
1) Remove the face plate off and cleaned the cog
2)Verify
the water supply to the valve
3)Verify valve to icemaker
works(unit has dual valve at rear bottom of fridge, switch plugs, then
press water dispenser and see if icemaker fill with water ) if fills
icemaker is bad , if not valve is bad. replace one or the other.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Unit runs but never gets cold
most likely you have a leak in the sealed system.if your compressor is running and not getting cold you most definately have leak.charging it wont help,you need to find where the leak is coming from and have it repaired and then have it charged.there is no place to check freon level.you could take the back panel out of freezer and you will see your coils and what type of frost pattern your getting if any at all.
Water leaking from front of refrig.
there is a drain hole located in the aluminum drain pan that needs to be flushed out with hot water. I use a turkey baster or a large syringe to do this it forces hot water thru and clears anything that's in the line..
Intermittant water leak under Kenmore side by side onto floor
Hi: Well, you have an inexpensive fix ahead. Your defrost drain is clogged. Look at the bottom of your freezer, the back wall. At the very bottom you will see a shallow funnel with a hole in the center. Usually a few slits in the metal above it for venting. This hole is not refrigerated and can also swallow a frozen pea or other morsel. Your defrost mechanism is also above it and uses it to drain the defrosted ice from the coils. Which it is not happening. Unplug and warm the freezer (put your food in a cooler) and you could pour some warm water and clorox bleach down the hole at the bottom. If it is just mold the clorox will eat it up. If its worse get a pipe cleaner (as in tobacco pipe) and work it in the hole. You have a cheap fix. Hope this helps, Jeff
Frigidaire leaking
the drain in the freezer compartment is frozen up you can remove all items from lower freezer and remove access panel on back of freezer compartment pick the ice out of the drain hole with a small screwdriver DO NOT USE SCREWDRIVER AROUND THE ALUMINUM COILS! once all ice is gone that you can see use hairdryer to blow into hole on medium heat. once it looks like it is gone take a small 1/4 plastic tubing and push down the hole to try to clear obstructions then run hot water down hole. if it still doesnt drain take rear access panel off of compressor area (back of refrig) look for drain hose and remove clamp take off and clean u might try this first. but you will have to remove ice from drain.
Frigidaire Upright Freezer keeps cycling on and off in short cycles
It is called short cycling. Help below
If your refrigerator is short cycling, it can be caused by a number of issues including: An incorrectly set thermostat inside your refrigerator. Dirt and dust on the coils that prevents efficient operation. Faulty capacitors or relays that prevent the compressor from staying on.
Apr 14, 2019
Possible Causes For a Short Cycling Refrigerator
A to Z Appliance Service
https://atoz1.com > News
I have a frigidaire freezer and its short cycling, it runs
JustAnswer
https://www.justanswer.com > Appliance Repair
Sep 30, 2014 - i have a frigidaire freezer and its short cycling, it runs about 6 to 10 minutes and then cuts off. what can be the problem and how can we fix ...
1 answer · Top answer: OK so there are only 2 things that can cause this issue---either the defrost timer or the thermostat ...
Frigidaire S/S not cooling, short cycling
Appliance Parts Pros
https://forum.appliancepartspros.com > posts > t55646...
Freezer or fridge does not cool at all. Evaporator fan runs, compressor try's to start and will hum/buzz for approx 7-10 seconds then an audible click and stops ...
Refrigerator short cycling and not cooling very well
Appliance Video
https://www.appliancevideo.com > question > refrigera...
Compressor turns on during the short cycling and does produce cold air and cold lines going to the evaporator in the freezer. biggest thing is during the 3 ...
Frigidair freezer compressor cycling on/off
HVAC-Talk
https://hvac-talk.com > vbb > threads > 53155-Frigidai...
Mar 7, 2021 - My Frigidaire freezer (upright) Model #FFU13F9GW is cycling. I hear the compressor try to kick on then shuts off after about 10 seconds. This has been ...
Domestic Refrigerator Short-Cycling
Dec 4, 2020
Wiring time delay for a short cycling compressor
Jun 23, 2022
Walk-in short cycles
Mar 7, 2021
Walk-in compressor short cycling
Oct 20, 2008
More results from hvac-talk.com
