20 Most Recent EuroCave Compact Wine Cooler Questions & Answers
Change door opening EuroCave v266. The manual says to lay it on its side to remove the bottom hinge, The same manual says not to tip more than 45 degrees when moving. Which one is correct?
In theory a fridge or freezer should not be laid down - ever, but sometimes it is unavoidable. If the fridge has been laid down it is best practice to allow them to stand upright for several hours, in the place where it is to stand and correctly levelled, to allow the oil to drain back into the compressor before switching on. The actual length of time varies depending on the opinion of who is giving it - I have heard everything from 4 to 8 hours. I would give it at least six and mostly would leave it overnight...
10/20/2020 3:07:07 PM • EuroCave... • Answered on Oct 20, 2020
2answers
Eurocave V183. Shelf 2-4 back wall icing. Removed ice, changed filter, keeps happening. Unplugged, let sit 24 hr. Dried it & restarted empty. Woke to ice. Noticed outside back wall icing as well.
Fridge/freezer freezing up-and no fanor air circulation: first check the defrost terminator thermostat it may have gone out. Thus not allowing the heating element to melt the ice.? AT TIMES The fan usually stops workingAND CAN MAKE FUNNY NOISES AS WELLdue to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature. May also need to check thedefrost timer,The defrost timer is usually found behind the front grill "toe kick" of the refrigerator.Or in the fridge compartment near middle top section. u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engageurdefrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providingurterminator is not bad? Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Placeurmeter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next. Takeurmeter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Nowur1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u knowurtimer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance.. Another item to check with a meter is theheating elementitself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS . Lastly check thecold control thermostatwith a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit? ALSO CHECK THE AIR FLOW VENT SYSTEMand THERMISTORSAt times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area! THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being putout. In most models around 1300( give or take 150 ohms) ohms is required https://www.youtube.com/watch?v=zmdsBkO46dk defrost therm. https://www.youtube.com/watch?v=6SJN8oaA2XE https://www.youtube.com/watch?v=buX9KcZo2c0 https://www.youtube.com/watch?v=gVXT7pZyk_o https://www.youtube.com/watch?v=53ZFeiWgtuk God is so good: so this is why I give free advice so please thank him not me. defrost timer location defrost terminator-undefined-undefined-0_0.jpg defrost timer testing defrost timer pins-undefined-undefined-2_2.jpg defrost thermostat test -undefined-undefined-5_1.jpg defrost terminator thermistordefrostterminator-undefined-undefined-9.jpg defrost timer oldermodel timerfrigi13-undefined-undefined-14.jpg
3/29/2020 8:36:52 PM • EuroCave... • Answered on Mar 29, 2020
3answers
Performance 283 1-temp not cooling....flshes
Hello & Welcome to FixYa
The problem is with the main power board that needs replacement; you can use warranty to get this done as these parts are usually covered less than 5-7 yrs. Please get back to me if you have any other questions.
Kevin
4/2/2014 7:58:21 PM • EuroCave... • Answered on Apr 02, 2014
0answers
EuroCave Compact Wine Cooler Logo
3 questions posted
Top EuroCave Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • EuroCave Refrigerators
Most Popular Question
change door opening eurocave v266
  • Refrigerators
