I heard a pop in my televison and now I have no pictiure or sound but the power is still on Can it...
(More)
I heard a pop in my televison and now I have no pictiure or sound but the power is still on Can it be fixed because it was hot and felt like something burned out How expensive will it be to fix it
when i turn on the air condition the engine doesnt accelerate but instead it cuts off. my mechanic...
(More)
when i turn on the air condition the engine doesnt accelerate but instead it cuts off. my mechanic says there is no step up switch and its the throttle body that is suppose to step up the idle when the A/C is turned on but my throttle is good. Please if any one could help me it would be greatly appreciated. its months now im trying to get some relief and i use my car for taxi but its a huge inconvience for people to travel with me and i cant turn on the A/C. Thanks so much in advance. MItsubishi Lancer Cedia (GDI 4G15 Engine the one with the electronic throttle body non cable)
when the tv is turned on a message at the bottom says the tv will turn off in a few seconds and to...
(More)
when the tv is turned on a message at the bottom says the tv will turn off in a few seconds and to check for blocked air flow
Hi i just got a new tv today and the channle buttons aren't working on the tv or in the menu key it...
(More)
Hi i just got a new tv today and the channle buttons aren't working on the tv or in the menu key it just skips right over it and i need to be able to change the channel to 78 to get my satelite to work!
There appears to be a dull clicking sound coming from the back of the tv when the channel is changed...
(More)
There appears to be a dull clicking sound coming from the back of the tv when the channel is changed or the picture is changed. This sound is more defined if the picture is dark and lighter segments of the picture appear on the screen.
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
written by Ecollier2012
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
