Panasonic PT-61LCX70 61 in. HDTV Television
Problems with Panasonic PT-61LCX70 61 in. HDTV Television?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Panasonic PT-61LCX70 61 in. HDTV...
Troubleshooting and Support
Solved Problems for Panasonic PT-61LCX70 61 in. HDTV Television RSS Feed
View More Results for Panasonic PT-61LCX70 61 in. HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Panasonic PT-61LCX70 61 in. HDTV Television RSS Feed
Answer
Red lamp light flashes five times then after about another hour Tv goes black you can shut it off... (More)
Answer
I have a Panasonic PT-61LCX DLP and I need to replace the lamp unit.
Answer
tv will not turn on. push power button green light comes on for 5 min. or so then green light goes... (More)
Answer
tv will not turn on, push the power button on and the green power light will come on but it flashes... (More)
Find a Manual
Panasonic PT-61LCX70 61 in. HDTV Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Panasonic PT-61LCX70 61 in. HDTV Television
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Panasonic PT-61LCX70 61 in. HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Panasonic PT-61LCX70 61 in. HDTV Television
Product MPN
MPN
PT-61LCX70
Key Features
Screen Size
61 inch
Digital TV Standard
HDTV · HDTV - HDTV receiver is integrated
Display Resolution
1280 x 720 pixels
Combo Features
Playable File Formats
JPEG
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
NTSC · ATSC
Digital TV Standard
Broadcast Format Supported
1080i (HDTV) · 720p (HDTV)
Broadcast Format Displayed
480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Image Quality
Comb Filter
3DYC / 3D Digital
Audio Features
Audio Type
Stereo
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Technical Features
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Energy Star Compliant
Connectors
Rear Input Connectors
1 x D-Sub (RGB PC)
Front Input Connectors
Composite x 3 · Audio (RCA) x 3 · HDMI x 3
Memory Card Slot
SD Card
Screen Text
OSD Languages
English · French · Spanish
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 20 Watt
Dimensions
Depth
19 in
Height
39.2 in
Width
56.4 in
Weight
74.9 lb
Warranty
Tube Warranty
5 Years
Panasonic Contact Information
Main support number800-211-PANA
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
