20 Most Recent
Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Questions & Answers
MY HAMILTON BEACH WATER DISPENSER
The heating and cooling sections are separate..these are not known to last very long. Sorry. (check the switches though - does the indicater light come on?)
Model YLR2-5-90HZ3 cold/hot/water dispnser with fridge won't heat
I have the YLR2-5-96H2 and hot water stopped heating up. I unscrewed the casing and unplugged the connections to the circular heating element and 2 circular probes. Brushed off the white dust build up on the probes and it started to heat water again. I ruled out faulty heating element, because it got really hot just seconds after turning on the hot water switch.
Cooler not running
Check power to relay. If yes, check compressor is working. If yes, keep your hand on discharge pipe. If it's not warm, cooler is under gas leak. Rectify leak and recharge gas.Thanks.
Need instruction booklet
Hi.
The only manual available is the one for the new 7SB series. The manual and the dispensers are practically the same. Please download the manual here:
FX-7SB user manualThe manual for FX-6SB can only be obtained contacting Whynter:
Phone: 866-WHYNTER Email:[email protected]
Part needed
I finally found contact info for the maker and I have a number to call in Canada to order the part.
