20 Most Recent Thetford Norcold DE0051 Refrigerator Questions & Answers
check fusible links and heater elements 12 volt and 120 volt also fuse in back on board
Thetford Norcold... | Answered on Dec 13, 2017
try blowing through the gas orifice with compressed air only.
Thetford Norcold... | Answered on Sep 12, 2016
Circuit board may need to be reset.
Thetford Norcold... | Answered on Aug 30, 2014
check for a gas shut off inside the fridge cabinet as well. You may have to bleed all the air out of the lines before the fridge will get gas. either keep trying or run stove burners to make sure gas is working. Also look for debris inside the burn chamber near the thermocouple/pilot light.
I had rust fall from the exhaust tube and block the burner area. Cleaned it up and it works fine now.
Thetford Norcold... | Answered on May 17, 2013
Check if you are getting voltage to the heating element should be 120 volts
there are two methods by which you can reset the circuit board, depending on the model of your refrigerator:
Procedure 1:
Click on the below link, scroll to the second (2nd) page. Read and follow the reset procedure.
http://www.rvtechlibrary.com/appliances/noco_old.pdf
Procedure 2: http://www.rvtechlibrary.com/appliances/noco_new.pdf
Good luck.
Thetford Norcold... | Answered on Jun 27, 2011
Thetford Norcold DE0051 Refrigerator Logo
56 questions posted
Top Thetford Refrigerators Experts
Steve Allison
Steve Allison
John Tripp
John Tripp
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Thetford Refrigerators
Most Popular Question
norcold n300 3 way works 110 but
  • Refrigerators
