20 Most Recent Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum Questions & Answers
4answers
High pitch
Sounds like you have a clog. Make sure the filters are clean, replace if it has been more then a year, check the inlet down by the brush roll, your clog maybe there.
11/16/2022 12:50:29 AM • Hoover Fusion... • Answered on Nov 16, 2022
0answers
I can't figure out how to get my Hoover Fusion Cyclonic canister open to empty it
read the owners manual it will tell you
12/27/2014 8:30:23 PM • Hoover Fusion... • Answered on Dec 27, 2014
0answers
0answers
HOW TO EMPTY FILTER
here is the manual > http://hoover.com/file/445/ enjoy
4/16/2013 10:34:59 PM • Hoover Fusion... • Answered on Apr 16, 2013
0answers
My hoover fusion carpet brush wont revolve
Hello, I hope your having a good day considering your problem.It sounds like you have done everything and more you can at your end. My opinion based on your detailed description is that is possible you might need to barrings in your roller on both ends. Now sometimes you can take it to a local vac shop (just the roller of course) and they can put the new barrings in as well as maybe it is possible that something is just loose or warn out. Sometimes you are better (for cost of repair reasons) to buy a new roller. I would first personally, take the roller off, and take in to local shop and have them give you a price to replace or repair. That appears to me what has happened. Its also possible, some dirt and debre has got trapped in where there barrings are and it is sticky or just plan stuck. Mike
12/4/2011 2:19:40 AM • Hoover Fusion... • Answered on Dec 04, 2011
Where is the belt located?
There are two buttons on the top cover marked easy belt access use a quarter to turn them lift cover off belt lift beater bar out put belt around right side of bar then slideit back in and pull the belt twords back you will see a metal pin it goes around it will be tight but not hard to do. spin the bar to make sure you have lined up straight put the cover back on tighten the two buttons if they will not tighten its not lined up properly Its harder to find a new belt than it is to put it on lol
11/29/2011 6:00:54 PM • Hoover Fusion... • Answered on Nov 29, 2011
I have one of these
At the base of the handle there is a button push it and the handle at the same time
11/29/2011 5:48:40 PM • Hoover Fusion... • Answered on Nov 29, 2011
I cannot release the
When you press the green release button the dirt cup should then pivot out, down and forwards.
6/17/2011 9:29:45 PM • Hoover Fusion... • Answered on Jun 17, 2011
4answers
Hoover fusion plus cyclonic upright vacuum
While I'm having a different problem, the problem you guys are experiencing can easily be fixed by cleaning the two internal filters. My vacuum did the same thing, just stopped running mid-stream. Remove the main filter cup. Look inside the cavity of the vacuum and you'll see a grey bar at the bottom of the cavity, pull this up and you'll find the first of two washable filters. Just rinse it under warm water squeezing as you rinse until the water runs clear. The roll the filter in a few paper towels or towel and unroll, reroll until completely dry - should only take a few minutes. Then, look in the same cavity except up top there is another filter which seems to be hidden. The back wall of the inside cavity will guide you to these filters as well. You will be amazed by the difference cleaning these will make in the suction power of your vacuum. Also, if you remove the belt cover and clean out the hose in this area it will improve suction as well. Hope this helps. Now, if I could just get the darn belt back on mine. First belt smoked and popped. Bought replacement belt, smoked and popped within seconds... HELP!!!
10/2/2010 5:10:32 AM • Hoover Fusion... • Answered on Oct 02, 2010
I need to replace the belt on my hoover fusion
Hello :
1:Unplug your Hoover vacuum. Turn the vacuum up-side-down and place the motor and vacuum portion on a counter top with the handle hanging down toward the floor. This makes it easy to work on the underside of the vacuum portion of the machine.
2:Locate the two plastic release levers near the front wheels of the vacuum. On most machines you will only need to push these levers outward with your thumbs to release the bottom panel of the vacuum. On certain older models, there are two screws that will need to be removed with a screwdriver. Once released, remove the bottom plate.
3:Locate the drive belt. Unless the belt is broken completely, it will be plainly visible. One end of the belt loops around the shaft of the vacuum's motor and the other end wraps around the vacuum's beater bar. The belt is in a modified figure 8. Use your fingers to stretch the belt slightly and remove it from the small shaft of the motor which will be almost dead center under the vacuum.
4:Remove the roller (the beater bar) that is across the front edge of the vacuum. In most models you can remove the bar by simply pushing it forward slightly and then lifting it up out of the U groove that it is held in. In some models you may need to use your screwdriver to push aside two clips that hold the bar in place.
5:Remove the belt (if attached) from the bar and then clean the bar. The bar may have hair and bits of carpet wrapped tightly around it, especially at the ends where the accumulated mess could prevent the bar from spinning freely. Use scissors or a utility knife to carefully clean off all hair and other debris. Make certain that the roller rolls smoothly and easily.
6:Place the new belt around the roller, fitting it into the groove in the middle of the bar. Replace the bar in the machine. In most models, the bar should simply drop down into the U grooves that hold it. Give the belt half a twist (like the figure 8) and then loop the free end around the shaft of the motor.
7:Replace the bottom of the vacuum and push the retaining tabs back in place with your thumbs or screw in the two screws that hold the bottom on. Turn the machine over, plug it in, and it should be working like new.
Things You'll Need: Replacement belt Screwdriver (for some models) Scissors Utility knife
Warning:
1:If your machine makes a screeching noise when you turn it on, then turn it off and unplug it immediately. Turn it over and check to see that the bar is seated properly before turning it back on again.
2:Never work on your vacuum if it is plugged in.
PLEASE RATE !
5/12/2010 12:33:36 AM • Hoover Fusion... • Answered on May 12, 2010
Just bought this Hoover Fusion vaccum used,
Loud noises from this model are caused by dirt build up on the suction fan mounted directly to the motor. Under the dirt cup there is a filter screen that should have a foam filter insert, when not used or cleaned properly allows dirt to get into the motor. Cleaning is the best option. Although if you are inclined, you can take it apart or take it to your local deaLer. I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
5/2/2010 6:28:43 PM • Hoover Fusion... • Answered on May 02, 2010
Is my model nno. US183900 S/N 080600079068 still
The Hoover Fusion Plus Cyclonic Upright Vacuum has a 1 year manufacturers warranty from date of purchase. You need to check your reciept to see if it's under a year old. Then go to the Hoover.com web site to find the closest Hoover warranty service center to where you live. Bring the proof of purchase and the vacuum to them.
4/8/2010 9:01:36 PM • Hoover Fusion... • Answered on Apr 08, 2010
When I turn on the vacuum dust blows out of the
THERE IS A PAPER FILTER THAT IS CLOGGED WHEN YOU PULL THE PLASTIC CONTAINER OUT TO EMPTY IT LOOK CLOSELY ON THE CONTAINER BOTTOM THERE IS SOMETHING THERE TO RELEASE AND THERE IS A FILTER CLEAN IT AND YOUR BACK IN BUSINESS
12/19/2009 2:50:58 AM • Hoover Fusion... • Answered on Dec 19, 2009
Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum Logo
Popular Tags
47 questions posted
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Hoover Vacuums
  • Hoover Vacuums
Most Popular Question
  • Vacuums
