20 Most Recent
HTC Advantage X7500 Smartphone Questions & Answers
When im playing my music
Just check the options on your media player. or try installing different players which suite to your requirement.
How do i stop being charged for the internet when
For you not to be charged for internet usage you may want to change the settings of your internet connections to 2G or GSM only. Since this band doesnt have capability to transmit data. Just follow the steps below.
Tap on Start
Go to Settings
Tap on Phone
Go to Band
Select your Network Type
Select GSM only or 2G
HTC X7500 Failure
I am having the same problem perhaps. the screen turned to multiple colors in lines- red, green, blue and white. I cannot even reset and do something.
How to unlock HTC advantage 7500, forgotten the
You may try default phone and security code to remove it
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
I have htc dopod/x7500 running
I assume you have been performing a "soft rest"
Back up your important data and perform a "Hard rest"
Please note that a hard reset will be set back to factory default settings.
Slide the Volume slider down and at the same time, use the stylus to press the RESET button at the back of your
device. After a brief period of time, two choices will appear on-screen. Press the CENTER OK button to perform the
hard reset. (Otherwise, if any, press the CAMERA button to exit.) Regards
License key for smart movie 4.15 that iam using
Unfortunately, Fixya does not provide crack license keys. Installing one means that you are taking away the right for your computers to be safe. Product updates, most especially the security patches will not be installed if you are using a crack key. One more thing, it is ILLEGAL.
Hi, my name is Walter. I have an HTC 7500 not upgrading
You can try with the sd card boot option,More info you can find here
http://www.resco.net/forums/ShowPost.aspx?PostID=2804
and here
http://pdaphonehome.com/forums/xda-mda-sx56-pocket-pc-phone-edition/48619-upgrade-failed-phoen-s-screwed-up.html
i tried it in the past and is working.
I got my HTC from school in 2007/8
when you say the 4 digit code at the start i think you are getting mixed up with the code to start the phone and the code you need to join the wireless network.
you will need to speak to whoever looks after the wireless network to get the password to join the network.
then go into system/connections and switch on the wireless network. it should automatically find the network and ask you for the password to allow you to join it... put the in the password the network administrator gave you.
Temperature problem on HTC 7501
Please, check your charger. The current compatible or not with specification your PPC. If the current little more battery temperature will be increase.
Ngajio.
