20 Most Recent
Philips MDV460 Questions & Answers
No sound when disc is in DVD player. Only picture.
The sound board is out in the dvd player. Try another source, such as cable, and/or a gaming system if the tv gets sound it is for sure the sound board on the dvd player. Always check to make sure the dvd player doesn't have a mute option.
No sound thru dvd player, but fine for tv and vcr
Just had the same problem and it is fixed for me. With NO DISC in the player go to the System Menu. Next Navigate to Preferences on the top of the screen.
You will set an option titled "Default". Select that and it seems to reset the player to default settings and fixes the sound.|
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
