20 Most Recent Epson Perfection 4490 Photo Scanner Printer Questions & Answers
The drop down menu does not give the option to
Please follow the steps below to scan and save a Multi-Page PDF with Epson Scan.
1. Launch Epson Scan from your START, (ALL) PROGRAMS, EPSON SCAN.
2. If prompted, select your scanner model. Epson Scan will now launch.
3. Click the drop down arrow next to SCAN, select FILE SAVE SETTINGS.
4. Select PDF for IMAGE format. Click OK.
5. Click SCAN. Click OK to proceed (if prompted).
6. Once the image has scanned you will be prompted to click ADD PAGE or DONE.
7. Click ADD PAGE to scan more documents.
8. Once you have scanned all your documents, click DONE.
9. Your documents will now appear in the EDITING PAGE window. Click OK.
10. The multi-page PDF is now created.
1/16/2010 2:41:22 PM • Epson Perfection... • Answered on Jan 16, 2010
Scan button suddenly appears as greyed out
Turn the printer off.Unplug the usb cable.Go to control pannel ans select add and remove.
Remove epson printer software.
restart computer.
download http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58611&infoType=Overview
Turn computer off.
plug usb cable back to printer and turn printer on,start the computer again,should fix the problem.
Sometimes they just get a file damaged.
11/13/2009 8:28:29 PM • Epson Perfection... • Answered on Nov 13, 2009
I have escndv.exe error problem with 4490 scanner.
The first thing to try is uninstall the Epson Scan. Via either the start
menu item if one exits or from the Control Panel Add/Remove Programs.
Reboot computer.
Install the latest driver from the epson web site -
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=50666&infoType=Overview
Latest is 2.68A for WindowsXP, etc.
You should go ahead and download a fresh copy from the web, your copy may be
corrupted.
After the install, reboot.
If that does not solve the problem.
You got to go deeper.
Remove the Epson scan. (again).
Backup your registry.
Edit the registry and remove all references to the Epson Scan.
Remove the folders and entries for Epson Scan in \Windows\Twain_32\
Reboot:
Install Epson scan.
Good Luck!!
10/13/2009 10:42:34 AM • Epson Perfection... • Answered on Oct 13, 2009
Epson problem
Here is the download page
http://www.epson.co.uk/Store/Scanners/Epson-Perfection-4490-Photo/Drivers-Support?supportLandingPage=true
To scan to PC you need to use a prog with twain support the basic one in XP is paint.(start/all progs /accessories/paint/file/from scanner or camera) the scan appears huge but that's just the way paint does it save and open with another prog for printing (eg windows fax and picture viewer) and it wil be printed normal size.
When installing drivers do not connect scanner until told to do so by the install prog.
9/16/2009 7:35:30 PM • Epson Perfection... • Answered on Sep 16, 2009
Escndv.exe problem connected with Epson scanner 4490 Photo
http://www.howtomendit.com/answers.php?id=64090
Go here: C:\Document
s and Settings\[username]\Application Data\EPSON\ESCNDV\ES0058
and delete any image files in that folder. The last folder might have a different number depending on your scanner. It should start working again.
If you can't see that folder - click on My Computer - in the menu click on Tools and select 'Folder options..." Click on tab 'View' and select 'Show hidden files and folders'
You should now be able to see 'Application Data' in Docs and Settings...
7/3/2009 1:44:15 AM • Epson Perfection... • Answered on Jul 03, 2009
Scanner driver for Epson Perfection 4490 Photo 10.5.6 doesn't wk
Epson has a Mac OS 10.5 support page HERE
There is a new beta driver section you may want to try and there are FAQ's for the perfection scanner with Mac OS..
I know it will work with your Mac... I've got the same one and it's working. All the drivers as there as well.
k
6/10/2009 3:59:06 AM • Epson Perfection... • Answered on Jun 10, 2009
2answers
Escndv.exe problem with Epson 4490 Photo scanner
1) RIGHT-CLICK on the MY COMPUTER icon and click on PROPERTIES.
2) Select the HARDWARE tab, then the DEVICE MANAGER button.
3) Remove the Epson Scanner from under IMAGING DEVICE and/or UNKNOWN and/or
OTHER DEVICES by RIGHT-CLICKING on it and clicking UNINSTALL.
4) Disconnect the USB cable and close all open windows.
5) Click on START, and CONTROL PANELS.
6) Double-click on ADD/REMOVE PROGRAMS. Highlight EPSON SCAN and click on
CHANGE/REMOVE.
7) Go to START, SEARCH, and ALL FILES AND FOLDERS. Select Advanced option
and ensure there is a checkmark next to SEARCH HIDDEN FILES and FOLDERS.
8)Search for files where all or part of the file named is OEM*.* and a word
or phrase in the file contains EPSON. Search location should be set to
C:\WINDOWS\INF or C:\WINNT\INF.
9) Delete all files that are found if this is your only Epson product. If
you have another Epson product, you will want to open each individual file
and determine which files pertain to your scanner, and then delete only
those.
10)Go to START, SEARCH, and ALL FILES AND FOLDERS. Search for files where
all or part of the file named twain.log . Search location should be set to
C:\. Please delete the twain.log file and repeat the process for
twain001.mtx, twunk001.mtx and twunk002.mtx. and epfb5 and escndv
Now we need to remove specific references to the product in the registry:
1. Click on START and then RUN.
2. In the Run window type in REGEDIT.
3. In the upper menu bar click on FILE, then EXPORT.
4. In the window that comes up, SAVE IN should be set to DESKTOP.
5. In the FILE NAME section at the bottom of the window type in REGBACKUP.
6. EXPORT RANGE should have a dot next to ALL.
7. Click on SAVE.
8. Look in the column on the left and Click on the "+" sign next to
HKEY_CURRENT_USER
9. Click on the "+" sign next to SOFTWARE
10. Click on the "+" sign next to Epson
11. Look for a folder name EPSON SCAN or epson twain . Right click on it
and Delete it (if you don't see it, then don't worry about it).
12. If you see a reference to your Epson product model, right click and
delete it.
13. Click on the "-" signs next to EPSON, SOFTWARE, HKEY_CURRENT_USER to
close up this branch.
14. Click on the "+" sign next to HKEY_LOCAL_MACHINE
15. Click on the "+" sign next to SOFTWARE
16. Click on the "+" sign next to Epson
17. Look for a folder name EPSON SCAN or epson twain , Right click on it
18. If you see a reference to your Epson product model, right click and
delete it.
19. Click on the "-" signs next to EPSON, SOFTWARE, HKEY_LOCAL_MACHINE to
DOWNLOAD
Please follow the steps below to download and install your scanner in XP:
1. Go to the website http://support.epson.com
2. Under the SCANNERS heading select PERFECTION SERIES and then your
scanner model.
3. Under the Drivers & Downloads section select Windows. Download the most
current version of the Scanner Driver for your Windows operating system to
your DESKTOP.
Reinstall
1) Double Click on the Epson1****.exe file that you downloaded to your
DESKTOP.
2) Click OK, Unzip, and then OK again.
3) The installer will copy the files to the system. Click on FINISH when
prompted.
4) Connect the USB cable to a different usb port on the computer. Windows
will tell you new hardware is found and complete the install.
5) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO
TESTING, click CONTINUE ANYWAY. Then click FINISH.
6) Your scanner is now ready to use. Add a reply
6/7/2009 11:54:30 AM • Epson Perfection... • Answered on Jun 07, 2009
Can't scan slides on Epson 4490
Please make sure that the option cable on the back of the scanner is seated properly.
You may need to trash and re-install the drivers.
To get the most recent driver compatible with your operating system, please log on to epson.com and go to the drivers and support page.
5/4/2009 3:37:53 AM • Epson Perfection... • Answered on May 04, 2009
2answers
Epson lq-690II printer reflects the paper when printing
Troubleshooting Paper Reversal in Printers: *Confirm that options related to paper handling are set correctly by checking for specific buttons or switches that relate to paper handling or reversing. *Ensure that paper is loaded properly to avoid feeding problems. *Remove any dust, particles, or paper remnants from the rollers, as they can impede paper flow. *If other measures fail, reset the printer to its initial settings to resolve potential software glitches.
4/2/2024 6:40:17 PM • Epson Office... • Answered on Apr 02, 2024
Old but New in box epson pictureMate photo lab has paper jam error but never had paper in it .what can i do ?
If you take is apart you may find jammed gears or dry lubricant causing a 'paper jam', due to its age and storage.
2/29/2024 9:14:17 AM • Epson Office... • Answered on Feb 29, 2024
EPSON 15140 error 034019
Try a hard reset of the printer. Oddly, the 034019 is not an error code, I have reason to think. It is a contact number, I believe.
2/25/2024 3:05:22 AM • Epson Office... • Answered on Feb 25, 2024
6answers
Reset my Epson printer L382
Follow the steps given below to reset Epson L382 printer. Step 1: Turn the printer off. Step 2: Press and hold the reset button which is on the back of the printer using a paper clip or tip of a pen. Step 3: Turn on the printer by holding the Power & reset button and continue to hold both the buttons. Step 4: Wait for 5 seconds and a warning sheet will print. Release the reset button. Step 5: After 5 seconds, another sheet will print which will show the IP address of the printer. hold the reset button which is on the back of the printer using a paper clip or tip of a pen. WHERE IS RESET BUTON? I CANT FIND IT.
1/30/2024 1:36:34 PM • Epson Office... • Answered on Jan 30, 2024
Head teperaturer error 43H code
I have the code on I dtf printer 43 H : Head Teperaturer
1/19/2024 4:27:06 PM • Epson Office... • Answered on Jan 19, 2024
Epson Perfection 4490 Photo Scanner Printer Logo
Popular Tags
19 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Epson Office Equipment & Supplies
Most Popular Question
epson problem
  • Office Equipment & Supplies
