20 Most Recent Symphonic WV806 DVD Player/VCR Questions & Answers
You want to control your Symphonic DVD/VCR combination with some brand/model of universal remote. What is the remote brand/model?
Symphonic WV806... | Answered on Jun 25, 2013
Dis-connect the plug from the wall receptical and other leads attached to to the unit. Next press and hold power for too minutes in an attempt to reset the microprocessor, now hook everything back up and power on, if this fails it probably would be cheaper to replace the combo than have it repaired.
Symphonic WV806... | Answered on Jun 05, 2012
Make a reset to this set. Refer its user manual for details about how to do this.
Symphonic WV806... | Answered on Jun 04, 2012
I have similar problem. I have recorded all of my old tapes on a DVD-RW disc (lots of time spent on it) and as I wanted to finalize them - it would display an recording error. Recently I purchased a new Sony blue ray player and I realized it would play the not finalized discs. I am still looking for a solution how to record these memories on a PC so I can edit them.
Symphonic WV806... | Answered on Feb 26, 2011
Yes.
You will need a dvd-R and it should be a record button on the dvd side that you push after starting the VHS on Vcr side.
Symphonic WV806... | Answered on Oct 28, 2010
you will need a dvd-R and it should be a record button on the dvd side that you push after starting the vhs
Symphonic WV806... | Answered on Aug 18, 2010
DVD-R and DVD+R should play once recorded and finalized. RW of any kind is iffy and must be tested to see if they will work.
I don't think any dual layer DVDs will work, but I could be wrong. If you're taking about recording DVDs on this, it's not a DVD recorder as far as I know.
Symphonic WV806... | Answered on Dec 29, 2009
There seem to be many types of these. Check the manual or website to see exactly which ones it uses.
There is no known region hack for this model.
Symphonic players are built by Funai.
I am reporting region hacks for different Funai models.
The procedures below may not work, but that is all the information available.
I suggest contacting Funai and asking region hack for the correspondent model Funai WV806:www.funai-corp.com/6pdf/om/WV806.pdf.
Models SV2000 WV10D6:
1) Hit CS
2) 2,5,1
then the menus appear. You will notice a selection of self test info that can be used to test the player, confirm the firmware both Front End & Back End, upgrade the firm ware as well as numerous other test modes.
3)Exiting the screens and returning to normal mode:
Changing Region code:
Hit CS
Then 6,5,0 for all region .
From Videohelp.
Funai FDRV90E:
using the remote; press cm-skip, cm-skip, 5, 1
gives an info screen with many test options and displays
region code etc. I can not find a way to edit the screen
with the region code
From Videohelp.
If the hacks do not work, Try contacting Funai: Contact Funai Customer Support.
Symphonic WV806... | Answered on Oct 13, 2009
It sounds like either the take up spool isn`t turning because the motor has failed or there`s something inside stopping the spool from turning or there may be something sticky around the skirt of the video head assembly. All I can suggest is remove the top casing and place a tape in the machine and watch what`s happening, Hopefully, you may find a child's toy or something similar under the cassette or the deck. Those labels that you place on tapes were notorious for coming off and finding it`s way into the mechanism. Ian
Symphonic WV806... | Answered on Aug 10, 2009
I`ve just downloaded these
VCR DVD Combo
Apex Digital 1061 VCR DVD Combo Go Video 0744 0715 VCR DVD Combo Hitachi 0000 VCR DVD Combo Panasonic 1762 VCR DVD Combo RCA 0060 VCR DVD Combo Samsung 1075 0820 VCR DVD Combo Sanyo 0104 VCR DVD Combo Sony 0864 VCR DVD Combo Sylvania 0675 0000 VCR DVD Combo Symphonic 0675 0000 VCR DVD Combo Toshiba 0503 This is the website http://www.ofausa.com/en/list_codes.php?db_value=expert4&remote_choice=URC 4021
And try this link as well http://www.ofausa.com/en/remote.php?type=URC 4021
Hope this is helpful, Ian
can't get the SV2000 dvd/vcr to record
Symphonic WV806... | Answered on May 24, 2009
Symphonic WV806 DVD Player/VCR Logo
53 questions posted
Top Symphonic Televison & Video Experts
Steve Allison
Steve Allison
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Symphonic Televison & Video
Most Popular Question
u record from vcr onto dvd symphonic
  • Televison & Video
