Troubleshooting & Support
Hot Topics:
- fuser temp
- oki b2520 reset
- reset
- b2520 fuser oki...
- oki b2520
- oki fuser temp
- printer error...
- reset oki
- b2520 reset
- b2520 driver...
- oki b2520 mfp
- download...
- fuser
- b2520 fuser...
- motor error
- installation...
- scanner error
- oki
- b2520 fuser...
- toner reset
- paper jam
- fuser unit fan
- b2520
- reset counter
- replace toner
- 2520
- c5950n
- fuser tem
- cartridge toner
- de
- View All »
Problems & Solutions
I have OKI B2500 and
You should place the card into the card reader at the front of the printer with the chip facing upwards. For the complete instructions on...
How to reset the toner count for OKI B2520
You have to replace the chip on the cartridge too. I am not aware if any replacement chips are available this time. Sorry.
Hi, I have an oki B2520
Flecha ABAJO Pulsar asterisco * Pulsar almohadilla # Poner en 1 el SC001 ok ok Y después Flecha ARRIBA Pulsar almohadilla # ok ok Y ya...
driver x b2520mfp multifunzione x
Hi Click hear to download the driver of OKI B2520. Cheer
ERROR IMPRESORA TEMPERATU. FUSOR
You may require a new defuser unit to help keep the machine cool whilst in opertation, contact your supplier or repair stockists.
I cannot adjust line and speaker volume on Oki
To print your terminal?s functions guide, press ▼ and enter 51 on the digital keypad. This guide lists all the commands that you can carry...
I do not have a manual for the printer here at the
You can download the manual for the B2520 at http://my.okidata.com/PP-B2520MFP.nsf?opendatabase Please rate this solution. Thanks.
where is the fuser
It has back side your copier or printer if itself you open all body and see your copier back side.
I have oki b2520 mfp printer and I want to refill
you get a gun and shot your self so you can die
B2520 reset now possible ? Is a card writer enough...
Here is some great PRINTER solution by Some FIXYA EXPERT. Get any kinds of PRINTER solution from bellow. » Lexmark Printer...
OKI MC360 I am getting Service
Hi, Welcome to Fixya. Service Call 980 This error refers to the Fuser unit - Media coiling error to the Fuser - Media is coiled to the...
I have just refilled toner
contact zinetic, they are very good at overcoming problems.
There's a paper jam in
You will have to pull hard and evenly to remove the paper. Often, the toner has built up on the fuser rollers, and the paper is actually...
does anyone know what is
I followed the July 10, 2009 instructions made in the comments. After taking it apart, I realized i had some tracing wire in my toolkit, and...
I have an OKI B2520
This is a common error especially if you have power surges or outages, before calling in follow the following steps: Press Down Arrow ...
Unsolved Problems
The machine is constantly beeping
The machine is constantly beeping at us and the message reads 'printer error fuser temp' and it wont print at...
i don't can change the
i don't can change the date and time of my oki mb290 in the guide say : you need enter in the parameter 21 (date...
have message printer error, fuser
have message printer error, fuser temp
oki b2520 "printer error fuser
oki b2520 "printer error fuser fan"
i have installes a OKI B2520 as a network printer
i have installes a OKI B2520 as a network printer through a Ethernet external disk. Can I send fax through my intranet...
toner card for oki 2520...how
toner card for oki 2520...how to get around this
When I select the main
When I select the main switch to ON it dont come ON . I checkek power connection and was OK.
I cant use the scanner
I cant use the scanner .... all the rest is fine Oki b2520 mfp
Manuals & Guides
TopDo you have a manual for OKI B2520 All-In-One Laser Printer? - Upload it to FixYa!
Upload a manual for OKI B2520 All-In-One Laser Printer
Specifications
TopKey Features
Full Product Name:OKI B2520 All-In-One Laser Printer
Platform:PC
Technology (Detailed):Laser
Black Print Speed:16 ppm
Output Type:Monochrome Printer
Max Resolution (BW):600 x 600 dpi
Printer Type:All-in-One
Technical Features
Form Factor:Stationary
Connectivity Technology:USB 2.0
Duplex Printout:Manual
Monthly Duty Cycle:1,000 - 9,999 (Individual)
First Page Out Time:13 Seconds
Media
Media Type:Transparencies
Media Type:Plain Paper
Media Type:Envelopes
Media Type:Labels
Max Media Size:Legal (216 x 356 mm, 8.5 x 14")
Total Media Capacity:250 Sheets
Multifunction Features
Copying Speed (Black):16 ppm
Zoom Range, Enlargement:400 %
Zoom Range, Reduction:25 %
Scanning Features
Scanner Type:Flatbed Scanner
Scanner Resolution:600 x 2400 dpi
Scanner Speed:3.9 Second
Faxing Features
Fax Speed:33.6 Bps
Fax Features Supported:Delayed Faxing
Fax Features Supported:Speed Dial
Fax Features Supported:Scan Into Memory
Memory
Installed RAM:4 MB
Max Memory:32 MB
Processor
Processor Speed:100 MHz
System Requirements
Operating System:Microsoft Windows 2000
Operating System:Microsoft Windows 98
Operating System:Microsoft Windows Millennium Edition
Operating System:Microsoft Windows NT
Operating System:Microsoft Windows 98 Second Edition
Operating System:Microsoft Windows XP Home
Dimensions
Depth:15.2 in
Height:16.22 in
Width:18.78 in
Weight:26.46 lb
What's your problem?
Fix-O-Meter
12,609
12,609 people have viewed this product
- 43 people asked about this product.
- 10 people found solutions for this product.
- 0 people have added this product. Be the first!
How to resolve...
Getting help...
How To Reset...
