20 Most Recent
Siemens CF62T Cellular Phone Questions & Answers
I saved voice mails but can;t find how to retrieve them? 911 !
Are you not able to retrieve new voicemails or only saved voicemails? Occasionally your carrier may delete old saved voicemails to make room for new ones.
If you want to save all old voicemails on your computer forever, you can sign up for a service like youmail.com
I need a free or low cost unlock code siemens
taking it that you need the PUK code to unlock the phone so that you can get the pin number to work
If that is the case PUK numbers are only available from your service provider
call them on another phone , provide proof that you own the account and they will give it to you
other than that , you may have to do a hard reset of the phone and get a new sim card and start fresh
POwer Turns off Unpredictably
I had the same problem, but replacing the original battery sorted it out. I also had the other software problem these phones are known for, where they suddenly switch off for no good reason. Remarkably, replacing the battery has fixed that problem, too! Don't bother looking for a Siemens battery. You can get an after-market replacement for around $20 online. You might be on to something about the planned obsolesence, though--my original charger just suddenly failed today. Fortunately an after-market replacement was pretty easy to come by.
Siemens C25 locked to carrier
If the carrier that originally locked your Siemens C25 is defunct and you can't get the unlock code from them, there are a few other options you can try:
- Use a third-party unlocking service: There are many online companies that offer unlocking services for mobile phones, including older models like the Siemens C25. You'll need to provide them with your phone's IMEI number and pay a fee for the service, but they can usually unlock your phone within a few days.
- Try unlocking the phone yourself: If you're technically inclined, you can try unlocking the phone yourself using software tools and a data cable. There are many guides and tutorials available online that can help you with this process, but be aware that it can be risky and may void your phone's warranty.
- Use the phone on a compatible network: If all else fails, you may be able to use the phone on a compatible network even if it is still locked. Check with local carriers in your area to see if they support the Siemens C25 and if they can provide you with a SIM card that will work with the phone.
