Fedders AEY12F7F Thru-Wall/Window Air Conditioner
Problems with Fedders AEY12F7F Thru-Wall/Window Air Conditioner?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Fedders AEY12F7F Thru-Wall/Window Air...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Fedders AEY12F7F Thru-Wall/Window Air Conditioner RSS Feed
View More Results for Fedders AEY12F7F Thru-Wall/Window Air Conditioner
Questions and Unsolved Support Problems
Unsolved Problems for Fedders AEY12F7F Thru-Wall/Window Air Conditioner RSS Feed
Answer
compressor will turn back on after unit is shut down, and when it is in this mode you cannot put... (More)
Answer
Unit will cool for hours then all the sudden it will blow warm humid air and if left running for... (More)
Find a Manual
Fedders AEY12F7F Thru-Wall/Window Air Conditioner Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Old motor has 3 wires, new motor has 4 wires, WTF?
You always want to save a few bucks in these tough times right? Don't want to spend a fortune replacing the motor with the exactamundo. So you... written by TheMobilian
Some central air conditioning unit solutions
outside works inside don't Nothing works Outside quit inside works written by TheMobilian
Air Conditioning Programmable Thermostats - Great for Heating and Cooling
Programmable thermostats contribute to overall system performance, maximizing energy savings while providing complete comfort control. They also allow... written by heatman101
How to Keep House Cool Without Using Air Conditioning
The expense of running the air conditioner is just too much. You open the house doors and windows up to try to cool the house down. But the house just... written by heatman101
outside unit fan replacement tip
Your central unit outside condenser motor is gonna someday die, that's a fact of life, will you pay some guy 450 dollars to replace a 75 dollar part?... written by TheMobilian
Ductless Split Air Conditioner Review
Ductless split air conditioning units are the very best thing for some situations. Of course they can be installed in the place of most any central... written by heatman101
Air Conditioner Trouble -Review the Possibilities
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check... written by heatman101
Air Conditioning - Cleaning the Condenser Coil
Air Conditioning works by exchanging heat from inside a building to the outside air. To do this some very basic refrigeration principles... written by heatman101
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for AEY12F7F Thru-Wall/Window Air Conditioner
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
Rate and Review the Fedders AEY12F7F Thru-Wall/Window Air Conditioner
Write a review:
Rate this product:
Would you recommend the AEY12F7F Thru-Wall/Window Air Conditioner to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Fedders AEY12F7F Thru-Wall/Window Air Conditioner
Other Features
Moisture Removal (Pt/h)
3.7
Filter
Reusable
Air Flow
262 CFM
Swing Louvers
Up / Down · Left / Right
Key Features
Remote Control
With Remote Control
Cooling Capacity
12000 BTU/hr
Energy Efficiency Rating
9.8 EER
Fan Speeds (Cooling)
AC Type
Thru-Wall/Window
Electrical Requirements
Voltage
208 / 230
Cooling Ampacity
5.6
Cooling Watts
1100
Heating Ampacity
13.4
Heating Watts
3560
Dimensions
Depth
21.75 in.
Height
15 in.
Width
23.63 in.
Fedders Contact Information
Main support number217-347-6459
Email supportcrsfreeform@fedders.com
Describe your problem:
Top Air... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
