20 Most Recent Vermont Casting VM450SSP Grill Questions & Answers
They are screwed in, you need to remove the screws and they slide out
Vermont Casting... | Answered on Jun 28, 2013
As is typical with Vermont Castings, when they discontinue a model (as is the case with yours), they discontinue any reference to it (Owners Manuals, Parts Manuals, Replacement Parts, etc.) and refrer the customer back to the VC Dealer. However, there are a few parts available through online grill parts stores. But they are pretty limited.
At one time, NEX Grill was manufacturing the VC Grills for Vermont Castings. You may want to check their website for availability of parts.
Hope this helps you find what you need.
Vermont Casting... | Answered on May 31, 2013
I don't believe a new ignitor will be necessary. But, you may end up having to purchase a new Hose/regulator Assembly. But, before we jump to that, here's what you need to do to troubleshoot and solve the problem. I am assuming, thtat there is adequate gas in the tank(?).
First, it would be a good idea to remove all the burners to clean them and the burner's venturi valve. The Venturi valve is located at or near the burner's open end. It will look like 2-slots cut into the each side of the burner. Spiders love to build nest in them. Since yours has been in storage, it probably has a few spiders. Before you attempt any cleaning of the burners, turn the gas tank valve OFF and disconnect to hose from the tank valve. The reason for this, will become clearer later.
After you have removed and cleaned the burners and venturi valves and reinstalled the burners, do the following:
1. Connect the hose to the gas tank valve.
2. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
3. Once the tank valve is fully open, light the burner farthest from the tank first and turn it to HIGH.
Did the burner light and does the flame height look as it should? If so, light the remaining
burners the same way. Now, do all the flame heights look as they should? If so, you solved
the problem (with a little help).
Whenever you turn the gas tank valve OFF. Remember to always turn it back ON Very, Very Slowly.
If the burners did not light and flame heights did not return to normal, you will need to replace the grill's Hose/regulator Assembly, because the regulator is locked up. You can purchase a new Hose/Regulator Assembly for about $30.00 at any home center or hardware store that sell gas grills and accessories. Take you old one with you for comparison purposes.
I hope this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Vermont Casting... | Answered on Jun 19, 2011
Vermont Castings only sells through its dealer network. I've provided the link to their dealer locator page:
Vermont Castings Find Local Dealers
Vermont Casting... | Answered on Jul 29, 2016
Its part of the burner which goes on the orifice is all in one just take out the burner .
Vermont Casting... | Answered on Sep 11, 2014
Since you have replaced the batteries, you now have to check the wires for shorts and the electrodes for a cracked/broken ceramic jacket. The gap may be to large between the electrode and the collector box or burner also.
Vermont Casting... | Answered on Apr 05, 2011
Vermont Casting VM450SSP Grill Logo
7 questions posted
Top Vermont Casting Grilling Experts
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Paul Carew
Are you a Vermont Casting Grilling Expert? Answer questions, earn points and help others
View Most Popular
  • Vermont Casting Grilling
Most Popular Question
replacing ignitor electrodes vermont
  • Grilling
