20 Most Recent
Philips HQ7742 Electric Shaver Questions & Answers
Hi where can i purchase
I dont know where you live but I would try wal-mart, maybe they would have it. If not then I would call Philips at 1-800-243-3050 and they should be able to help you.
Blade for Philips HR1115
https://www.google.com/search?q=Blade+for+Philips+HR1115&oq=Blade+for+Philips+HR1115&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Philips sonicare toothbrush turns itself on
Its haunted. you need a priest to bless it with holy water.
Or the button is stuck with toothpaste. Mine did that and the battery ended up failing a few weeks later. New ones are lot cheaper than when I bought my first sonicare.
My philips Sonicare airfloss won't shoot fluid when I press the button.
If the spray of your Philips Sonicare AirFloss becomes less powerful or stops spraying all together, you can often fix is yourself. Just follow these steps.
Clean the vent
There is a small vent in the reservoir door opening to let air in as water is drawn out of the reservoir for every burst. If the vent is blocked it will reduce and eventually stop the water flow.
If this vent is blocked, you must clean it using the following steps:
- Use a piece of paper towel or a cotton swab.
- Moisten (not soak) the paper towel or cotton swab in water.
- Clean the vent by wiping along the inside edge of the reservoir opening especially at the top of the opening closest to the nozzle end of the device.
- Also wipe along the outside of the inside edge of the reservoir door along the top of the door closest to the nozzle end of the device.
- Rinse very well with cold tap water and ensure no debris is left, from the paper towel or cotton swab, in the reservoir or along the edge of the opening or the inside of the door.
- Be careful not to allow debris into the reservoir fill opening.
