20 Most Recent Canon Pixma Mg5250 Imageclass Inkjet Scan Copy 9600 X 2400 Dpi Sc Questions & Answers
Claim from removal firm for new printer and anything else they broke / damaged. Their insurance will cover it.
Canon Pixma... | Answered on Feb 17, 2016
often a power cycle is all it takes. there may be a reset 'hole' activate reset with a paperclip.
Canon Pixma... | Answered on Aug 22, 2014
As long as the cartridge that is telling the printer I'm empty is in the printer, you can't go on. I did reset all my colour cartridges in my printer, because I only print in black. Still now and then a cartridge is telling it is empty. I think the printer still wants to mix colours in the black. Lucky me, I can reset my cartridges all the time.
I'm not sure you can do the same on the canon. Try to get a chip resetter that is sold on all refill stores.
Canon Pixma... | Answered on Jul 18, 2014
You cannot solve it by yourself.
This error means, that the wast ink absorber is full and needs to be replaced. When a new waste ink absorber has been installed, the device needs a reset. This can only be done by Canon service.
In the printer driver settings, where you can select the paper type, you have to choose "other paper" and select "T-Shirt Transfer".
With the canon single ink inkjet printers it is not possible to use only the black cartridges for printing. You will have to put a new cyan cartridge into the printer to continue printing.
Canon Pixma... | Answered on May 30, 2014
Did you check, nothing is in the paper feeder? Could be just a little piece of paper or a staple is blocking proper functioning of the feeder.
Keep the paper try clean and take care you never drop or leave anything in the printer, that does not belong there.
Canon Pixma... | Answered on Mar 09, 2014
Install your cartridge into the Epson printer.Go to "Start > Control Panel" on your computer.Double-click on "Printer.Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.Click "Save" and close the windows. Your cloned ink cartridges should now work.
Epson may also display an error message if you refill the ink cartridges.
Read more: http://www.ehow.com/how_6163069_make-printer-recognize-clone-cartridges.html#ixzz2knfFsjd6
Canon Pixma... | Answered on Nov 16, 2013
You don't.
Dots per inch (dpi) is an output parameter when printing your pictures. It's often determined by the printer and its driver.
The camera has no idea what printer(s) you are using. Since it has to put something in the dpi field, it selects 72. Most cameras do the same.
The dpi will change depending on the size of the print.
You can change the dpi field using any good photo editing program.
Canon Cameras | Answered on Apr 19, 2019
Amazingly, I can not even find an image of this device even at the canon support sites. I have encountered an image of a purported support service manual covering the z90 as well as the z60 but the links tend to point to suspicious sources which might or might not bilk you. I can only suggest you contact canon support in the UK to see if they might provide some information. The Canon support sites do not even offer a brochure or FAQ about such. What little information I encounter suggests the machine pre-dated Windows 7 and seems to have used 32 bit software, at least originally.
You might have to search forums for information about this device if Canon is unresponsive. I can't find out enough about it to write anything else possibly useful. There do seem to be other models of this ColorPass device mentioned at the Canon sites. Sorry.
Canon Cameras | Answered on Apr 14, 2019
You've got it on Time Lapse video. Turn on, slide to video, press func. set button, toggle to standard instead of time lapse. Always check your owners manual.
Canon Cameras | Answered on Mar 28, 2019
restore your camera settings to the factory default:
  1. Press the Menu button. ...
  2. Use the Multi-controller to navigate to the Camera Settings 4 tab.
  3. Use the Multi-controller or the Quick Control dial to highlight Clear All Camera Settings and then press Set.
SADLY I HAVE NO CLUE IF WHAT YOU WANT TO TRY CAN BE DONE . ONLY YOU CAN TRY IT TO FIND OUT
Canon Cameras | Answered on Mar 19, 2019
Canon Pixma Mg5250 Imageclass Inkjet Scan Copy 9600 X 2400 Dpi Sc Logo
16 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Cameras
  • Canon Cameras
Most Popular Question
error 5700 mean fixable
  • Cameras
