ACCO Brands Apollo Projector Screen
Problems with ACCO Brands Apollo Projector Screen?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for ACCO Brands Apollo Projector Screen RSS Feed
Click here to get instant support from our best Experts!
View More Results for ACCO Brands Apollo Projector Screen
Questions and Unsolved Support Problems
Unsolved Problems for ACCO Brands Apollo Projector Screen RSS Feed
Answer
The screen can not rewind into its case. I stretched the screen, but it is blocked when I try to... (More)
Answer
I have a large tripod stand with an Apollo screen. The top of this stand needs to be replace. I'm... (More)
Answer
Hi my office uses an apollo projector screen and it seems the spring or whatever device that... (More)
Answer
I have a 70x70 Tripod Appollo and the part at the screen hook over and raises the screen is missing.... (More)
Answer
I think I might have raised the screen up too high and a little black plastic piece broke inside and... (More)
Answer
We installed our screen at a new location, pulled it down and now we cannot get it to go back up.... (More)
Find a Manual
ACCO Brands Apollo Projector Screen Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
The Fl231 PROBLEM(CONVERGENCE NOT IN CUSTOMER MENU) ITC22 chasis
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and... written by willtab
Updated! Convergence Problems & Solutions - With example photos
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV... written by Ecollier2012
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for ACCO Brands Apollo Projector Screen
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the ACCO Brands Apollo Projector Screen
Owners Recommend
out of 4
Reliability
Ease of use
Value for Money
Rate and Review the ACCO Brands Apollo Projector Screen
Write a review:
Rate this product:
Would you recommend the Apollo Projector Screen to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for ACCO Brands Apollo Projector Screen
Supported Models
60300, PT7070SB, RW9696
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
