i can use ps3 menu just fine, when i try to play gta4 is says "this game cannot be played with...
(More)
i can use ps3 menu just fine, when i try to play gta4 is says "this game cannot be played with these video settings" i have tried i think every setting possible on ps3 and projector. any help greatly appreciated.
ps3 wont connect to my optoma 65 projector all i get is a blue screen its connected via hdmi and no...
(More)
ps3 wont connect to my optoma 65 projector all i get is a blue screen its connected via hdmi and no matter what ive tried i cant get a picture from the playstation HELP!!
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
written by Ecollier2012
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
