20 Most Recent Andis T-Outliner Hair Trimmer Questions & Answers
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Andis T-Outliner... | Answered on Feb 09, 2019
The blade alignment probably just needs adjustment, if you undo the two blade screws a fraction you should be able to move the comb or bottom blade further forward then re-tighten the screws.
Andis T-Outliner... | Answered on Jan 17, 2016
Adjust your blade. Remove it from the clipper, and then loosen (don't remove) the two screws that hold the blade and cutting edge together. Use a FLAT surface, like a ceramic sink top or flat piece of tile, and push the cutting edge down and angle the blade with the cutting edge facing the flat surface down to about a 30 to 35 degree angle. Use your thumb to hold in place until you can retighten the screws. Under a light, inspect to see if it is level (it will be noticeable if it isn't) or oil the blade and touch it to a clean dry piece of paper. If it is level, replace the blade on the trimmer, and edge your beard. It should be better than brand new. This also works when it doesnt seem like the blade is cutting sharp anymore. ALWAYS make sure the cutting edge is lower than the blade or you WILL CUT YOURSELF or YOUR CLIENT!
Andis T-Outliner... | Answered on Jan 16, 2016
The Andis T-Outliner that you purchase from the USA is not for UK voltage 220 50 HZ, the Voltage is too high, the only way to control the voltage is transformer from 220V to 120 V. The Andis Trimmer that may work for you is the GTX trimmer this trimmer was manufactured for Canada and there voltage is 220V 50HZ.
Manny's Sharpening 323 237-2885 f175053b-23eb-4546-bbc5-bb86bc86dcf9.jpg Manny Mobile Sharpening and Clipper Parts Supplies
Andis T-Outliner... | Answered on Jan 01, 2015
This unit will not work correctly in the UK as it has a magnetic motor. No matter how you try to tune it it will be very loud and eventually the motor will burn out.
Andis T-Outliner Hair Trimmer Logo
68 questions posted
Top Andis Health & Beauty Experts
Bruce Showalter
shaveroutlet.com
shaveroutlet.com
Anthony Ward
Anthony Ward
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Andis Health & Beauty
Most Popular Question
makes loud noise when turn
  • Health & Beauty
