FixYa.com
JVC KS-AX3300 Car Audio Amplifier
All Products > JVC > Car Amplifiers
Problems with JVC KS-AX3300 Car Audio Amplifier?
Search inside JVC KS-AX3300 Car Audio Amplifier Knowledgebase
Troubleshooting and Support
Solved Problems for JVC KS-AX3300 Car Audio Amplifier RSS Feed Post a New Problem
I have a new receiver with a preamp...
I have a new receiver with a preamp output, high volume, and I want to feed that into my power amp. Do I need to...
1 Solution
Problem
I am having trouble keeping my amp on when I turn up my stereo. I am running it in stereo setting on the LPF and I have...
1 Solution
american legacy II LA690 amp
i want to know if there is any way you can bypass the overhaul (green light:power, red light:overhaul) because when ever...
1 Solution
Need a power connector for a Boss IQ 3KD.1...
Where can I find a replacement power connector for a Boss IQ 3KD.1 3000W Class D Monoblock Amplifier. The screw loosened...
1 Solution
Amp isn't putting out any sound
My amp just up and quit and now it won't put out any sound. It will power on but that is as far as it gets and the LED...
1 Solution
what ohm load is best?
is the lowest ohm wire configuration gonna get the best sound out of your amp? ive got a 1 ohm stable amp, is that what...
1 Solution
Can a Y be put on the amp for the remote...
Have one gain/crossover control next to driver's seat, was thinking of putting one in the trunk near the rear window,...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Amplifier TypeDual Channel
RMS Power at 4 Ohms65 W x 2
RMS Power at 2 Ohms90 W x 2
Performance
Signal to Noise Ratio86 dB
JVC Contact Information
Main support number(800) 252-5722
Email supportproinfo@jvc.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
