FixYa.com
Mobile Authority A300 Car Audio Amplifier
All Products > Mobile Authority > Car Amplifiers
Problems with Mobile Authority A300 Car Audio Amplifier?
Search inside Mobile Authority A300 Car Audio... Knowledgebase
Troubleshooting and Support
Solved Problems for Mobile Authority A300 Car Audio Amplifier RSS Feed Post a New Problem
I´ve got 2 amps for my subs,but only...
I´ve got 2 amps for my subs,but only one pre-out from HU of course.i know i should be using amp´s line out to...
1 Solution
Need a power connector for a Boss IQ 3KD.1...
Where can I find a replacement power connector for a Boss IQ 3KD.1 3000W Class D Monoblock Amplifier. The screw loosened...
1 Solution
Amp isn't putting out any sound
My amp just up and quit and now it won't put out any sound. It will power on but that is as far as it gets and the LED...
1 Solution
what ohm load is best?
is the lowest ohm wire configuration gonna get the best sound out of your amp? ive got a 1 ohm stable amp, is that what...
1 Solution
8 Ohm Load? Why?
I was playing with the woofer wiringwizard, and for (2) 4 Ohm subs it shows how to wire it so the amp sees 8 Ohms. i was...
1 Solution
power light
My amps power light does not work, is there anyway I can make it work again?
1 Solution
12.6 from battery
In recent topics I heard that a regular car battery with no upgrades can have about 12.6 volts. My? is if an amp such as...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Amplifier TypeDual Channel
BridgableBridgable
Performance
THD at Rated RMS Power0.03 %
Signal to Noise Ratio95 dB
Crossover / Equalizer
Bass BoostWith Bass Boost
High - Pass Frequency55 Hz - 4200 Hz
Low - Pass Frequency35 Hz - 155 Hz
Other Features
3 Way ReadyNo
MOSFET CircuitryYes
Dimensions
Depth8 in.
Height2.5 in.
Width10.88 in.
Mobile Authority Contact Information
Main support number800-848-6748
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
