FixYa.com
Jenn-Air JDS8850 Dual Fuel  Kitchen Range
All Products > Jenn-Air > Kitchen Ranges
Problems with Jenn-Air JDS8850 Dual Fuel Kitchen Range?
Troubleshooting and Support
Solved Problems for Jenn-Air JDS8850 Dual Fuel  Kitchen Range RSS Feed Post a New Problem
My surface element has to be...
My surface element has to be "jiggled" or pushed in to make it work....what may be wrong ?
1 Solution
How do I clean my tempered glass surfaces?
1 Solution
How do I clean my control panel on my...
How do I clean my control panel on my range or oven?
1 Solution
Surface element doesn't work
I have an electric kitchen range. What do I do if the surface element doesn't work?
1 Solution
oven and clock inop
on the display there is one red dot that is all. the clock and oven is inop. thank you for your help in advance.Roy...
1 Solution
oven not working properly
Everthing about the range seems to be working properly, except the oven. When turned on, the burners do not produce a...
1 Solution
Oven does not light
When I turn on the oven, the display goes to PrE (preheat mode) but the oven does not heat up. The ceramic igniters are...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Jenn-Air JDS8850 Dual Fuel  Kitchen Range RSS Feed Post a New Problem
downdraft
my downdraft fan will not turn off. my range is two years old and looks slightly different than the JDS8850(black...
Post a Solution
burner ignition
I have one burner that will not ignite. The gas is availible at the burner. The 3 other burners will igniter lite when...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Fuel TypeDual Fuel (Electric and Gas)
Element TypeBurner
No. of Cooking Elements4 Elements
Oven AmountSingle
Self CleaningWith Self Cleaning
Range TypeSlide-in Range
Additional ElementsSimmer Element
Other Features
Exterior ColorBlack · White
Additional FeaturesPilotless Ignition · Oven lights · Oven Door Window · Storage Drawers
Capacity4 cu. ft.
Convection TypeWith Convection
Oven FunctionalityBake · Roast · Broil
Sabbath ModeWith Sabbath Mode
Dimensions
Overall Depth26.19 in.
Overall Height35.75 in.
Overall Width30.75 in.
Warranty
Warranty1 Year
Jenn-Air Contact Information
Main support number1-800-688-1100
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
