Jenn-Air 30 in. CVG4280 Gas Cooktop
Problems with Jenn-Air 30 in. CVG4280 Gas Cooktop?
Troubleshooting and Support
Solved Problems for Jenn-Air 30 in. CVG4280 Gas Cooktop RSS Feed Post a New Problem
Igniter keeps firing
I just recently installed new burners on both sides of my range. I also removed the knobs and cleaned the range top....
1 Solution
Ventilation system on Jenn Air CVG4280
The ventilation system will come on when the grill burner is in use. It is not suppose to come on when the burner...
3 Solutions
Jenn-Air 30in. Exaust problem
The fan will come on if the grill is not turned on, or if the burners are on and I need some exhaustion, but as soon as...
1 Solution
exhaust fan not starting
The downdraft fan is sticky and will not start on my Jenn Air cooktop. If I help it it eventually catches
1 Solution
exhaust fan comes on when burner turned on
Jenn-Air exhaust fan comes on every time the left two burners are turned on. It seems to work fine with right two...
1 Solution
Miele gas cootop
I just broke one of the 5 bakelite buttons on my Miele gas cootop. The part number is TN 34575=541 tfsw. Please...
1 Solution
Circuit Braker Jump Off Easily on GE JP350...
Could you help me troubleshoot why the circuit braker jumps off so easy on GE JP350 Cooktop, even only with two units...
1 Solution
Unsolved Support Problems
Unsolved Problems for Jenn-Air 30 in. CVG4280 Gas Cooktop RSS Feed Post a New Problem
Top Right Burner will not ignite
When I move the top right burner control to ignite, the ignitor does not fire. The bottom left burner works fine and if...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Fuel TypeGas
Number of Cooking Elements2
Element TypeBurner
Cooktop TypeFixed
Dimensions
Overall Depth15.63 in.
Overall Height21.5 in.
Overall Width29.88 in.
Jenn-Air Contact Information
Main support number1-800-688-1100
Sponsored Links
Loading problems.
Top Experts
Ask Me
fridgetec Guru
2 solutions
Ask Me
Oceti Guru
1 solutions
Ask Me
ranger25 Wiz
1 solutions
Repair Service
Find Kitchen Cooktop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
