20 Most Recent
Creda C362E Electric Kitchen Range Questions & Answers
Not heating up
If fan is working o/k , then you need to replace the heater element.
This is located behind a removable panel at the rear of the oven compartment,
Undo screws and remove element .disconnect leads, be careful not to lose them inside, fit new element, fit cover back.
Plz rate this solution.
Tthanks, and merry exmas.
How to change a grill element, cant mave the 2
Just had same problem, requires a short nosed Philip's cross cut screwdriver. I couldn't get them to turn either when using a cross cut with any length of blade beyond the actual cross cut part.The element screw heads are very shallow. Hope this helps,.
We have a Creda Concept
Press and hold down the two left buttons on the panel together and then press the plus or minus buttons to reset the time to the current time.
How do I get a manual on a Creda Concept Solarglo Cooker
When i turn on the kitchens rings,they turn on for 10 seconds and after turn off for half minute and this process continue to repeate again and again. The indicates of screen change allte time, and i dont know whats happen with the kooker.Please inform me what to do. Thtank you!
