20 Most Recent Kenmore Elite 44723SS Commercial Refrigerator Questions & Answers
Check to be sure the coils and compressor are free of dirt , lint and so on.
Kenmore Elite... | Answered on Jul 07, 2013
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Kenmore Elite... | Answered on Jul 30, 2011
My friend, I don't know what your question is though it is obvious you are upset about something. I don't recognize your question nor your 'handle' and I don't believe I replied to you at any other time.
I can tell you that the people who answer questions here are, by and large competent and caring, reasonable people and reasonably good at what they do. Some are professional and others (like me) learned by doing; I'm just an ordinary guy trying to assist others with their troubles on my day off from the regular job. We are all trying to help folks like you with your problems. I am not compensated in any way for this response to you - I am not an employee of FixYa.com. You will have an opportunity to rate my response and of course you can rate this response high or low or in between. Frankly, I would like a good evaluation, but it doesn't affect my bottom line in any manner. I don't know what your problem is so I cannot make a comment to help you, except to say ...
I am sorry you are disappointed with the response you received. If you paid for your response, there are remedies for you through the site. When you opened your account, you were directed to the Terms of Use. You had to indicate you understood the terms and agreed before you could proceed. Several of the terms say basically "... be nice while you are here - no attacks please ..." I now kindly suggest to you that you return to the Terms of Use (link below) and review the method you should follow to get your money back, if you paid for anything, that is. BTW, your comment, this comment, that I am responding to, appears in the "free section" of FixYa.com. Normally, paid questions do not appear in this section.
Thank you for your interest in FixYa.com and thanks for the feed back. Be assured that I will try harder when I make my comments to others in the hopes others will not return a comment like this to me.
Thank you and God Day.
Kenmore Elite... | Answered on Jul 11, 2011
all major appliances come with a manufacturers one year warranty. So if its been within the year then contact the manufacturer cause your still covered.
Kenmore Elite... | Answered on Apr 30, 2011
This is normal - it is defrost liquid evaporating.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Kenmore Elite... | Answered on Apr 28, 2011
I found this to be quite up your alley... gives you possibilities for DIY repair.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Kenmore Elite... | Answered on Apr 13, 2011
Check the oring seal for damage. If it is not in place - the filter will not fit properly.
Kenmore Elite... | Answered on Sep 30, 2010
i didn't find a Guide buy if you type in Kenmore Elite 44723 SS in at YouTube.com a bunch of videos come up with all kinds of help and repair videos
Kenmore Elite... | Answered on Aug 16, 2010
Hi: I don't know how much you mean by to much water, but that model uses a simple ice maker. If it's just a little water over flowing; Put a level on it and make sure the ref and ice maker are sitting level. If too far out of level the ice maker will leak water. Try this before calling service. I hope this helps, Jeff
Kenmore Elite... | Answered on Jun 09, 2009
Kenmore Elite 44723SS Commercial Refrigerator Logo
29 questions posted
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
kenmore elite ice maker stop working
  • Refrigerators
