20 Most Recent Fruity Loops Image Line FL Studio 10 Signature Edition Academic Lab Pak Questions & Answers
The serial number will be on the packaging that came with the software that you legally bought.
Fruity Loops... | Answered on Dec 06, 2017
Are you sure that the lid safety interlock switch isn't damaged/dirty? If the centrifuge can't detect that the lid is closed it will never start. Sometime it just needs an extra push down on the lid.
Science &... | Answered on Jan 17, 2018
It sounds like either the bulb is loose or the connection between the bulb socket and a wire is loose. To check both, Loosen the screw knob on the underside of microscope and open the panel to expose the bulb. Use a small screwdriver to loosen the screws holding (the two screws closest to the bulb) the prongs of the halogen bulb. Note that the prongs of the bulb are held in place by small brass plates which shift slightly when the screws are loosened. Remove the old bulb. Important: Do not touch the new halogen bulb with bare hands. Wear gloves or hold the bulb using tissue or lens paper. Body oils may damage the halogen bulb. Insert prongs of replacement bulb into top of socket (above the brass plate) and tighten screws slightly. (The brass plates will move up to hold the prongs in place.) Close door and hand tighten the thumbscrew knob.
If this does not work, contact Premier for assistance: Premiere® Microscope Service, 7241 Gabe Court, Manassas, VA 20109 (703) 330-1413
Science &... | Answered on Jan 15, 2018
The error E61 indicates that your water pump has failed or is not active. You should check the pump and replace it if needed. You should also check the steam generator sensor and replace it if needed.
For more information, contact Euronda at Water inlet pump inactive or call (+39) 0445 329811 (Vicenza, Italy)
If this is a microscope, the part you are referring to is the stage control. You can get the part from C&A Scientific at http://www.cnascientific.com or by calling 703.330.1413
Soak in a product like lime away first. Glass lenses cant warp without heat. Plastic even crystal type can absorb minerals. Ultrasonic can help clean all of them. The lime away will remove almost all trace minerals, lye or powdered drain cleaner will remove organics. Gool luck let me know how these ideas woek for you.
Science &... | Answered on Jan 05, 2018
I think the number you gave is the microscope serial number, to hope to get help you need to find the model number so people can help. At least post a picture. In general the microscope needs a light source to be bright enough to use. The transformer is meant to provide power to the light. If you use the microscope with a light shining through the object held by a glass slide then the light is below the stage which holds the object. Sometimes on simpler microscopes they have a mirror below the stage and you shine a bright light beam into the mirror and must adjust the angle to reflect the light through the slide. In more complex systems the light is built into the microscope. For opaque objects you must shine the light from above onto the object. If you can't find the official Nikon light source to connect to the transformer, you may be able to get non Nikon light sources. For my stereo microscope for example, I use a LED ring-light I bought on ebay for ~$25. This lights the objects from above and fits around the microscope tube just above the stage.
Science &... | Answered on Dec 27, 2017
Your question is hard to answer without more detail, including movement rate and required magnification. For relatively slow moving objects you can use a movable stage (X-Y stepper motors tied to a computer). Usually the direction of motion is erratic or unknown, and some digital tracking software will have to be written to drive the steppers so as to follow the designated object of interest. This may be something you have to develop yourself, although there may be some "tracking" software commercially available (or adaptable).
Note that you usually cannot take a video of the object as you track it, due to the quantum action of the stepper motors. However, this does not keep you from taking a series of stills (step - capture - step - capture - step ... etc.) and turning them back into a stop-action video. There are a lot of free or cheap programs out there to do that.
If the motion of the object is rapid, then you have a much bigger problem. One project I did some years back had this problem, and we could not actively track the sudden motion with a microscope. What we did instead was to reduce the microscope magnification, and significantly up the resolution of the high-speed camera (and yes, that was very expensive). At 1500 FPS, we could capture the object as it moved rapidly across the stage, then post-process the resulting frames to center on the object. The obvious limit here is that the object needs to cover a relatively small portion of the overall picture - which limits the magnification you can use. Of course, the offsetting advantage of this method is that you pay more for the camera, but don't have to have a movable stage on the scope.
Science &... | Answered on Dec 06, 2017
you need the software for that microscope from the manufacturers web site suitable for win 8 64 bit
Science &... | Answered on Nov 20, 2017
Note: Administrator default password is admin.
Science &... | Answered on Sep 27, 2017
Damage to an expensive precision instrument can result in loss of functions, distorted results, costly repair or replacement. There is also risk of contamination and injury. Damage can result from misuse or lack of maintenance.
Safety Maintenance
http://www.wpro.who.int/mvp/lab_quality/2096_oms_gmp_sop_12.pdf
Science &... | Answered on Sep 09, 2017
Fruity Loops Image Line FL Studio 10 Signature Edition Academic Lab Pak Logo
4 questions posted
Top Fruity Loops Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Fruity Loops Science and Laboratory Expert? Answer questions, earn points and help others
View Most Popular
  • Fruity Loops Science & Laboratory
Most Popular Question
m asking fruityloops 12 sefrial number
  • Science & Laboratory
