20 Most Recent
Jenn-Air JS48SEDBDA Stainless Steel Side by Side Refrigerator Questions & Answers
Jenn-Air JS48SEDBDA, sn 1271791 will not cool both freezer and refrigerator
The number reason for the Jenn Air no cool situation is caused by a break down of hte PAG oil in the compressor, thus clogging the capilary tube at the filter drier area, and causing contamination within the system. Per the Maytag TSB, a new compressor kit, heat exchanger, and new liquid line drier are required to be replaced. The compressor kit should come with a new main logic board. The ramaining componants need to be completely purged with nitrogen till clean. The condensor coil must be clean and free of any dust. A new lower freon charge follows the completed repair, and replacement decal to show new charge.
4/11/2014 12:37:06 AM •
Jenn-Air...
Answered
on Apr 11, 2014
My fridge/freezer has lost all
Hi chillrefrige,
This is an indication of a bad main control board. The main control board is located in the compressor compartment. The part # for this is 67006853. You may order part from
Sears or from any other place online. Instruction sheet is provided along with the part.
Hope this helps.
Thank you for using FixYa.
8/15/2011 11:37:55 PM •
Jenn-Air...
Answered
on Aug 15, 2011
The freezer is not as
Hi Jim,
I am currently working on that model for a friend, the higher number the colder that compartment will get, it is not advisable to go any higher than 5 or 6, because this will reduce air to the refer section. Is the fan working in the freezer? I have seen problems with this model, and when the drain pan to the evaporator clogs, then the water freezes around the fan motor and stops it from functioning.
Get back to me and I could lead you in the right direction if needed. I’m happy to help further over the phone at
https://www.6ya.com/expert/gere_bf68e6055dd61249
8/14/2011 4:06:45 AM •
Jenn-Air...
Answered
on Aug 14, 2011
Icicles in my freezer; ice-maker motor is frozen! 2d time in 1 mo
Hi
This may have happened because of a clog in the drain pipe and/or due to the ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. Also check the water valves wiring as given in this
link. Please see these links for more details:
JS48SEDBA 48" Jenn-Air refrigerator
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
7/28/2009 12:27:37 AM •
Jenn-Air...
Answered
on Jul 28, 2009
Original cost of my fridge from 1999
2389 model
Jeff of Clayton, CA
Original review: June 2, 2006
We purchased a
Jenn-Air JCD2389GES side by side four years ago. We thought we were buying a quality refrigerator, with a name brand that was respectable and with the idea that you get what you pay for. We went ahead and spent
$2200 on purchasing this and within a year noticed that it made noises, the refrigerator side didn't stay cold and the freezer side froze food that developed freezer burn with in a week. Just this past week the refrigerator was on the coldest setting and the food was slightly above room temperature. A hundred dollars of food had to be thrown away.
The best way to find old prices is to find reviews. The best ones are on websites that do reviews themselves as they always list the price.
https://www.google.com/search?q=jenn-air+jcd2289atb+review
5/30/2022 4:00:51 PM •
Jenn-Air...
Answered
on May 30, 2022
