20 Most Recent Jenn-Air WW27430P Stainless Steel Electric Double Oven Questions & Answers
We have similar Jen Air double oven and with the same problem but only on the lower oven. The doors are interchangeable and the top door fits fine but the lower door will not close completely at the top. It does turn out the light but has never cooked properly. I checked with several appliance repair shops and the hinges are not adjustable, but since one door closes and our other doesn't it is not a hinge problem, just a defective design.
We let this go too long and are out of warranty so I doubt Jennair is going to do anything. I hope someone post a solution but it is clearly not problem with the henges but with the receptacle they go into.
Jenn-Air... | Answered on Jul 10, 2014
Capacitor C3 a 68uf 35v could be faulty. Check this link out if you wish to attempt a repair - http://www.badcaps.net/forum/showthread.php?t=7902
Jenn-Air... | Answered on Jun 30, 2014
can't help you with the noise. The knobs should only go back on one way - look at the shaft that the knob goes on, and it should not be a perfect cirlce - one side is flat. The knob should be the same way. Match them up, and push the knob down.
Jenn-Air... | Answered on Jan 21, 2014
The display sits on a circuit board. Pull the board out and replace capacitor C3. It is 68 micro farads. I used a 47 from Radio Shack and it works great. If you can find a 68, that would be ok too, of course!
Jenn-Air... | Answered on Dec 31, 2012
Dim display indicates a "failing" electronic oven control. It will continue to get dimmer and dimmer until it fails completely. You need to replace the "clock" (sometimes called the ERC <---Electronic Oven Control)
This is a tricky repair. Be sure you have the power off (at the breaker box) before attempting this.
Tracy
Jenn-Air... | Answered on Dec 19, 2011
Hi
It could be a gone element, burnt switch, thermostat, or oxidized connectors that push onto the element. Dead element is most common cause. All these can be tested with a multimeter on the low resistance
range. If you're able to make sure it's fully unpowered, it's not hard to check which the problem is and replace.
Please check this links to troubleshoot your problem:-
http://www.partselect.com/range-stove-oven+repair+repair.htm
http://www.selfhelpandmore.com/appliances/how-to-fix-your-electric-oven.php
Jenn-Air... | Answered on Apr 29, 2011
Hi Sir!
This is Alpug.
Is this question intended to a particular expert that answered your question before?
I want to help sir! May I know the parts of Jenn-Air WW27430P that are you looking for?
Please post back!
Jenn-Air... | Answered on Nov 17, 2010
This would indicate the actual display of your oven is failing, it does happen, sometimes they last for 30 years, sometimes as little as a year...
Is this a Jenn-Air WW27430P as indicated?
Please reply and confirm and I can find the part for you.
Thanks
Tim
Jenn-Air... | Answered on Nov 15, 2010
Looking at the schematic I see 2 possibilities:
1. I think the most likely cause is a failed "limit switch" aka "thermal fuse" aka "temperature cutout". For each oven there is a limit switch that feeds power to both elements. So the upper limit switch is probably tripped which would kill power to the upper bake and broil elements. The limit switch is usually located on the back wall of the oven cavity.
2. There are a relay board for each oven. Be sure you changed the right one.
Best Regards,
Bruce
www.fixyourboard.com
Jenn-Air... | Answered on Jun 20, 2010
Hi.
FC error is Control Board communication error.
Try to reset the error disconnecting power for two minutes.
Trip the circuit breaker or disconnect power cord.
If that does not clear the error, the appliance must be taken apart to test ribbon cable to display panel and buttons.
Here all parts and diagrams.
If you need to call a technician, or if you want to get a quote on repair you can use the number listed on the owners manual.
Regards.
Jenn-Air... | Answered on Nov 18, 2009
Sounds like another control board failure, common on this type oven. It appears that a capacitor (#C3 on board) overheats and goes bad. Replacement of cap is a simple soldering job but the caps can be hard to find, try electronics parts houses and explain you need a high temp replacement. Should cost you about a buck. See post by BrianGem back in may of 2008, who turned me on to the target cap. Its a 35Volt 86mF. DISCONNECT OR TURN OFF POWER PRIOR TO ANY REPAIRS.
Jenn-Air... | Answered on Aug 12, 2009
Sounds like another control board failure, common on this type oven. It appears that a capacitor (#C3 on board) overheats and goes bad. Replacement of cap is a simple soldering job but the caps can be hard to find, try electronics parts houses and explain you need a high temp replacement. Should cost you about a buck. See post by BrianGem back in may of 2008, who turned me on to the target cap. Its a 35Volt 86mF. TURN OFF OR DISCONNECT POWER PRIOR TO ANY SERVICING PROJECT.
it seems there is a electrical defect, a malfunction, you can try to unplug it for 24 hours and see if that will make a difference if not there is not much you can do.
Jenn-Air... | Answered on Apr 14, 2009
Jenn-Air WW27430P Stainless Steel Electric Double Oven Logo
27 questions posted
Top Jenn-Air Ovens Experts
Craig Butler
Craig Butler
Paul Bade
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
View Most Popular
Jenn-Air Ovens
  • Jenn-Air Ovens
Most Popular Question
dim display
  • Ovens
