20 Most Recent
Seaga Manufacturing SM26 Commercial Refrigerator Questions & Answers
Sm26 needs a capacitor what is mfd rating
Normally a capacitor of rating 8-10 mfd /450 volt can be siufficient for the single phase motor and since you have not mentioned the capacity it is ideal to check on the old one after cleaning the dirt off with soap and water or with diesel oil. A hum on the motor will confirm that the capacitor is faulty and if the capacitor on applying direct AC( 230) does not pick up charge then it is faulty.
6/7/2012 3:57:30 AM •
Seaga...
Answered
on Jun 07, 2012
I do repairs for a
The compressor which they supplied(Samsung) is very low capacity one and it will not do the work equal to the previous compressor
As they say they use this for SM26 soft drink distributor try connecting it. And check the performance if you have the same performance as the previous compressor then it wont be the problem.If the performance is less then change it.And before connecting have a talk with the parts provider that you will return the product if you do not get satisfactory performance.If they accept for it then connect this compressor.
Thank You
9/7/2010 2:11:47 PM •
Seaga...
Answered
on Sep 07, 2010
Russell Hobbs Fridge not working?
Humming is a classic sign that the start / run capacitor for the compressor has failed. Call for service, have it checked for gas and condenser cleaned.
How to remove drip tray at back of aeg fridge
On an AEG SANTO 3533, the tray sits on top of the compressor. There is a short metal "tunnel" on top of the compressor. The tray has a plastic clip in the middle which goes through the tunnel and latches up on the other side. To remove, reach to the back of the metal in the middle of the tray, press the plastic clip firmly down, and pull/wiggle the tray backwards horizontally to remove. Needed a torch to see clearly on mine. One of these things that's easy once you've done it once.
When Should You Consider Copper for Water Storage?
Copper has anantibacterial effect. Studies recommend storing water in copper containers for several hours before consumption to maximize this benefit. Some research suggests 48 hours. perhaps explore dedicatedcopper water bottlesfrom reputable sources for optimal water storage.
This refers to water, not juices.
