Home
My Products
Sign In
All Products
Jenn-Air
Ovens
Problems with Jenn-Air JJW8130D Electric Single Oven?
Add to Warranty Manager
Search inside
Knowledgebase
Troubleshooting and Support
Post a New Problem
oven door
My oven door came off its hinge...how do you instal it back
1 Solution
jenn air oven stuck closed after attempt...
My wall-mounted jenn air oven door is stuck closed after a failed attempt to activate the self-cleaning function. I...
1 Solution
DeLonghi doubleoven electric cooker ESS602
The lower oven has ceased to heat up. The fan works.
1 Solution
Foil baked onto oven base.
I recently got a new Westinghouse oven and put foil on the bottom to keep it clean while I was cooking in my second day...
1 Solution
Viking electric range
The timed AC outlet,the oven light and fluorescent light all failed at the same time.Fuses are all good, bulbs...
1 Solution
Bosch HBN 642 -- single oven cycles and...
I own a 7-8 year-old Bosch wall mounted single oven, HBN 642 A UC. Problem 1: in bake convection and regular bake mode,...
1 Solution
Wolf oven stove top starting problem
Hi - We have had our Wolf oven for about 8 years now and it just recently started having problems with each burners...
1 Solution
View All
Tips & Tricks
Post a New Tip
Be the first to Post a New Tip
WikiManual
Post a New Chapter
How to Make and Use a Solar Oven
by wikihow
How to Preheat an Oven
by wikihow
Manuals & Guides
Post your Manual or Guide
Be the First to upload Manual or Guide
Specifications
Key Features
Self Cleaning
With Self Cleaning
Oven Functionality
Bake · Roast · Broil
Oven Type
Single
Energy Source
Electric
Other Features
Design
Built-in
Number of Racks
Cooling Fan
With Cooling Fan
Sabbath Mode
With Sabbath Mode
Door Opening
Top Opening
Programming Options
Cooking Start
Dimensions
Overall Depth
24.44 in.
Overall Height
28.25 in.
Overall Width
29.75 in.
Warranty
Warranty
1 Year
Jenn-Air Contact Information
Main support number
1-800-688-1100
Sponsored Links
Bogda
Let one of our
Experts Solve
your Problem
DO YOU WORK FOR
JENN-AIR
Register as STAFF
Top Experts
reg501
New Products
Powered by
Repair Service
Find Oven Repairman Near You:
Advertise Here
Find Parts
Order Jenn-Air Ovens Parts Here
powered
by
Get this Widget
