20 Most Recent
Gaggia 7001 \ 7002 Electric Burr Grinder Questions & Answers
Can't get the grinder grind adjust to turn.
Chances are something is caught on the inside feed to the grinder. Try turning the machine upside down over the sink and turning the switch left and right at the same time. Whatever is causing the jam is likely to fall out.
Gaggia titanium leaking from the bottom
If the machine only is leaking while the water tank is attached, but is correctly inserted, then the intake line could be broken or disconnected. This will require a repair. If leaking only occurs while the machine's pump is activated then the drain area of the machine might be blocked
