FixYa.com
Intel Network adapter
All Products > Intel > Network Adapters
Problems with Intel Network adapter?
Troubleshooting and Support
Solved Problems for Intel Network adapter RSS Feed Post a New Problem
Best PCI 10/100 Mbps NIC in terms of...
I was curious as to everyone's interpretation as to the best PCI 10/100 Mbps NIC for use on a server. I've been...
5 Solutions
PRO/100 Server Adapters and Novell 4.11
We are also experiencing the same communication hang up problems reported by others on this forum.   Hardware:...
5 Solutions
PRO/100 Server with NT SP5
Hi John, I'm referring to my e-mail dated 2 June. I don??t have a solution nor an answer to my problem. We??ve...
5 Solutions
Hi, i have problems with Intel Pro/100 Server card (660114-006). After usage of windows NT servicepack 5 no more...
2 Solutions
EtherExpress PRO/10 ISA bus BNC
I have been running a network on Win 95 with your product PCLA8215B for about two years with great success. Now I...
1 Solution
TCPIP and Netware
There is a problem using the PRO/10+ PCI Lan adapter (#PILA8500) in a mixed server environment(Novell Netware 4.1 and...
2 Solutions
10/100 Intel netport Express printing...
Hi, I have the following problem Brother HL720 on intel netport - parallel connection. Windows 95 network...
2 Solutions
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Package Qty.20 · 5 · 1 · 6 · 100 · 30
Form FactorExpansion Card · Internal Adapter
Cable FunctionAdapter
Cable TypeNetwork
Cabling TypeEthernet 100Base-TX, Ethernet 10Base-T · Ethernet 10Base-2, Ethernet 10Base-T · Ethernet 1000Base-T, Ethernet 100Base-TX, Ethernet 10Base-T · Ethernet 1000Base-TX, Ethernet 100Base-TX, Ethernet 10Base-T · RJ-45 · Ethernet 1000Base-T · Ethernet 100Base-FX · Network · Ethernet 1000Base-LX · Ethernet 1000Base-SX · Token Ring · SCSI · Ethernet 10GBase-LR · Ethernet 10Base-T · Fiber Optic · Ethernet 100Base-TX
Max. Data Transfer Rate10 Mbps · 54 Mbps · 16 Mbps · 2 Mbps · 155 Mbps · 400 Mbps · 25 Mbps · 1 Mbps · 200 Mbps · 10000 Mbps · 132 Mbps · 100 Mbps · 1000 Mbps
Interface CompatibilityPCI-X · PCI, PCI-X · PCI-Express · PC Card (Cardbus) · PC Card · PCI · ISA
ConnectorsRJ-45 · SC · LC
LAN StandardsIEEE 802.3 CSMA/CD or Ethernet, IEEE 802.3u 100 Mbps (Fast Ethernet) · IEEE 802.1p LAN Layer 2 QoS/CoS Protocol for Traffic Prioritization, IEEE 802.1Q Virtual LANs (VLAN), IEEE 802.3 CSMA/CD or Ethernet, IEEE 802.3u 100 Mbps (Fast Ethernet), IEEE 802.3ab 1000 Mbps (Giga · IEEE 802.11b 2.4 Ghz 11 Mbs Wi-Fi · IEEE 802.1p LAN Layer 2 QoS/CoS Protocol for Traffic Prioritization, IEEE 802.1Q Virtual LANs (VLAN), IEEE 802.2 LLC, IEEE 802.3 CSMA/CD or Ethernet, IEEE 802.3u 100 Mbps (Fast Ethernet), IEEE 802.3ab · IEEE 802.1p LAN Layer 2 QoS/CoS Protocol for Traffic Prioritization, IEEE 802.1Q Virtual LANs (VLAN), IEEE 802.3ab 1000 Mbps (Gigabit Ethernet), IEEE 802.3x Flow Control · IEEE 802.1p LAN Layer 2 QoS/CoS Protocol for Traffic Prioritization, IEEE 802.1Q Virtual LANs (VLAN), IEEE 802.3ab 1000 Mbps (Gigabit Ethernet), IEEE 802.3ad Link aggregation, IEEE 802.3x Flow Control · IEEE 802.1p LAN Layer 2 QoS/CoS Protocol for Traffic Prioritization, IEEE 802.1Q Virtual LANs (VLAN), IEEE 802.2 LLC, IEEE 802.3ab 1000 Mbps (Gigabit Ethernet), IEEE 802.3x Flow Control · IEEE 802.1p LAN Layer 2 QoS/CoS Protocol for Traffic Prioritization, IEEE 802.1Q Virtual LANs (VLAN), IEEE 802.3ae 10 Gigabit Ethernet, IEEE 802.3x Flow Control · IEEE 802.1p LAN Layer 2 QoS/CoS Protocol for Traffic Prioritization, IEEE 802.1Q Virtual LANs (VLAN), IEEE 802.2 LLC, IEEE 802.3 CSMA/CD or Ethernet, IEEE 802.3x Flow Control · IEEE 802.2 LLC, IEEE 802.5 Token passing Ring · IEEE 802.1p LAN Layer 2 QoS/CoS Protocol for Traffic Prioritization, IEEE 802.1Q Virtual LANs (VLAN), IEEE 802.3ad Link aggregation, IEEE 802.3x Flow Control · IEEE 802.1p LAN Layer 2 QoS/CoS Protocol for Traffic Prioritization, IEEE 802.1Q Virtual LANs (VLAN), IEEE 802.2 LLC, IEEE 802.3z Gigabit Ethernet over fiber standard (1000BaseX), IEEE 802.3x Flow Con · IEEE 802.3 CSMA/CD or Ethernet · IEEE 802.2 LLC · IEEE 802.3x Flow Control · IEEE 802.3z Gigabit Ethernet over fiber standard (1000BaseX) · IEEE 802.3ad Link aggregation · IEEE 802.3ab 1000 Mbps (Gigabit Ethernet) · IEEE 802.3u 100 Mbps (Fast Ethernet) · IEEE 802.1Q Virtual LANs (VLAN) · IEEE 802.1p LAN Layer 2 QoS/CoS Protocol for Traffic Prioritization · IEEE 802.3c 10 Mbps Ethernet · IEEE 802.11a 5 Ghz 52 MBs
Standard Data-Rate(s)10 Mbps, 100 Mbps · 1 Gbps, 10 Mbps, 100 Mbps · 10 Gbps · 16 Mbps, 4 Mbps · 1 Gbps · 10 Mbps · 100 Mbps
Duplex ModeHalf Duplex, Full Duplex · Full Duplex
Fiber Signaling ModeMultiMode · SingleMode
Networking ConnectorsRJ-45
Other Features
MTBF720201 Hours
LED Indicators100 Mbps, Tx Activity, Rx Activity, Link · Rx Activity · Tx Activity · Link · Activity
Bus Clock Rate133 MHz · 66 MHz · 33 MHz
Bus Clock Bits64 bit · 16 bit · 32 bit
Power Requirements5 Volts · 12 Volts · 2.2 Volts · 3.3 Volts
Power ManagementACPI, Wake-on-LAN · ACPI, Wake-on-LAN, MagicPacket · Wake-on-LAN · ACPI
ManagementSNMP · DMI 2.0 · DMI · SNMP, DMI 2.0
Max Fiber Distance550 Meters · 10000 Meters · 275 Meters
Connectors
Left Connector TypeRJ-45 · D-Sub · BNC · 26 Pin
Left GenderMale
Right Connector TypeRJ-11 · 68 pin CTbus
Right GenderFemale
System Requirements
PlatformPC, Unix · PC
Operating SystemMicrosoft Windows XP · Microsoft Windows 95, Microsoft Windows NT · Microsoft Windows 3.x, Microsoft Windows NT · Microsoft Windows 2000, Microsoft Windows 95 · Microsoft DOS, Microsoft Windows 95, Microsoft Windows NT · Microsoft Windows Server 2003 · Microsoft Windows 2000 Server · Microsoft Windows 2000 Advanced Server · Microsoft Windows 2000 Datacenter Server · Microsoft Windows 2000, Microsoft Windows 95, Microsoft Windows 98, Microsoft Windows ME, Microsoft Windows NT, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional · Microsoft Windows NT, Novell NetWare, UnixWare · FreeBSD · Artisoft LANtastic, Banyan VINES, IBM OS/2, Microsoft Windows 95, Microsoft Windows NT, Novell NetWare · Artisoft LANtastic, Microsoft Windows 3.x, Microsoft Windows NT, Novell NetWare, UNIX · Linux, Microsoft DOS, Microsoft Windows 2000, Microsoft Windows 98 SE, Microsoft Windows ME, Microsoft Windows NT, Novell NetWare, Microsoft Windows XP · Linux, Microsoft Windows 2000, Microsoft Windows 98 SE, Microsoft Windows ME, Microsoft Windows NT, Novell NetWare, Microsoft Windows XP · FreeBSD, Linux, Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Novell NetWare, SunSoft Solaris, UNIX, UnixWare, Microsoft Windows XP · FreeBSD, Linux, Microsoft Windows .NET, Microsoft Windows 2000 · Linux, Microsoft Windows 2000, Microsoft Windows 95, Microsoft Windows 98, Microsoft Windows NT, Novell NetWare, SunSoft Solaris, UnixWare · Banyan VINES, IBM OS/2, IBM OS/2 LAN Server, Microsoft DOS, Microsoft LAN Manager, Microsoft Windows 3.x, Microsoft Windows 95, Microsoft Windows NT, Microsoft Windows NT Server, Novell IntranetWare, · Artisoft LANtastic, Banyan VINES, Microsoft Windows 3.x, Microsoft Windows NT, Novell NetWare · Banyan VINES, IBM OS/2 Warp, Microsoft Windows 3.x, Microsoft Windows NT, Novell NetWare · Microsoft Windows NT, SCO OpenServer, UnixWare · Linux, Microsoft Windows 2000, Microsoft Windows 98, Microsoft Windows 98 SE, Microsoft Windows ME, Microsoft Windows NT · Linux, Microsoft Windows 2000, Microsoft Windows 98 SE, Microsoft Windows ME, Microsoft Windows NT, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional · FreeBSD, Linux, Microsoft Windows 2000, Microsoft Windows NT, Microsoft Windows Server 2003, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Novell NetWare, SunSoft Solaris, Unix · OpenUNIX 8 · Microsoft Windows 98 · Microsoft Windows 95 · Novell NetWare · SunSoft Solaris · UnixWare · Microsoft Windows NT · Linux · Microsoft Windows 2000
Warranty
Warranty1 Year · Lifetime · 90 Days · 3 Years
Dimensions
Depth6.8 in.
Height4.7 in.
Width6.6 in.
Weight.8 oz.
Supported Models
 711269-003 ,  729757-007 ,  7356d , 0060CFEF, 0060cfef., 01N0523, 100BTNIC, 10BTCEM33-20PK, 15515207, 20 Pack, 338478N, 351361003, 351361-003, 3C905B-TXM /N, 3C905B-TX-W, 3C905C-TX-MSED, 3C905CX-TXNM /N, 3C975UTP /N, 3c985b-sx /n, 3C985-SX/N, 5 Packs, 520019, 5423817, 54-23817, 6001460, 6001910, 656993002, 660114006, 660114-006, 704920002, 704920-002, 711269-003, 717037003, 717037-003, 72975700, 729757-00, 729757-007, 7356D, 742365005, 751767004, 770001750, 960001-04 more...
Intel Contact Information
Main support number800-404-2284 / 916-377-7000
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
