I have HD writer AE when I try to burn a dvd from my panasonic movie cam I get the message Disc not...
(More)
I have HD writer AE when I try to burn a dvd from my panasonic movie cam I get the message Disc not supported what does this mean? and how can I burn a dvd from my digital camera if I can't use this program? untechnocrat
I bought a dvd from America and now find that it is the wrong area or zone code it is 1 for the USA...
(More)
I bought a dvd from America and now find that it is the wrong area or zone code it is 1 for the USA and 4 For NZ. How do I change my code from a 4 to all?.
Thankyou
For any discs i inserted to the player, it said the disc is not supported.... what can i do now......
(More)
For any discs i inserted to the player, it said the disc is not supported.... what can i do now... and sometimes the dvd tray cannot be opened and closed. i can hear some stange sound everytime the tray is malfunctioned.
Thanks for help~
p.s. my model is DVDR3455H/97
will not load dvds will say no disk . will play cds music sound is good fm radioeverything works no...
(More)
will not load dvds will say no disk . will play cds music sound is good fm radioeverything works no movies
I have DvD R5500HDMI I have alittel proplem with the conection could you please explain to me which...
(More)
I have DvD R5500HDMI I have alittel proplem with the conection could you please explain to me which cables shall i use also i faild to conect this DvD with sky thanks for help
while watching a dvd film ,the picture on the tv went into pause mode (frozen) also the door on the...
(More)
WHILE WATCHING A DVD FILM ,THE PICTURE ON THE TV WENT INTO PAUSE MODE (FROZEN) ALSO THE DOOR ON THE R520H PLAYER WILL NOT OPEN (THE DISC IS LOCKED INSIDE).
I opened the unit up and it appears that it is the power supply. I have checked all over and can't...
(More)
I opened the unit up and it appears that it is the power supply. I have checked all over and can't find a power supply. Does anyone know where I can get the power supply. A couple of the transistors were discoloured and no power was at the output connections.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
