20 Most Recent RCA Lyra M2030 MP3 Player Questions & Answers
maybe 64 songs depending on the songs size
RCA Lyra M2030... | Answered on Jan 19, 2017
go to walmart and buy the cheapest digital camera and I promise the cord is exactly the same. Also Motorola uses the same cord.
RCA Lyra M2030... | Answered on Dec 07, 2009
it is a cheap MP3 and the screens are known for cracking if you are too rough with them. the same happened to mine.
put in and take out only when Mp3 is turned off.
Check the lock/unlock switch on the top of the unit. What you described has happened to me, and that is what the problem was.
RCA Lyra M2030... | Answered on Nov 22, 2009
Make sure it is downloaded to the correct folder. The ebook folder. It will be under DCIM folder
RCA Lyra M2030... | Answered on Oct 28, 2009
try out the rca website under the support section they usuly have it there
RCA Lyra M2030... | Answered on Oct 05, 2009
On the back of the player there is a button to the right. Above the button it says Off and below it there is a picture of a key. Switch the button upwards to turn the lock thing off.
RCA Lyra M2030... | Answered on Jan 14, 2009
Try a new/different USB cable. My Lyra was a painful thing with cables. Also, make sure the plug and receptacle are clean. Improper connection can do this.
Also, you should have gotten a driver CD for the player. It contains the correct drivers for the lyra, and will help Windows XP use the correct USB drivers.
Try those and see what happens. It may just be corrupted USB drivers.
Hope it helps bud!
RCA Lyra M2030... | Answered on Sep 21, 2008
Ipods and MP3 players also host virus, even if these cannot be infected directly, they CAN infect the PC you connect it to.
Plug in your player to a PC with a good antivirus and do a scan.
Also, check the battery, it might be worn out as well.
RCA Lyra M2030... | Answered on Sep 13, 2008
I had the same problem. I solved it by first backing up all the music on the device, then reformatting the internal flash memory, then copying my music back on to the . I am a linux user, so this was done with "mkdosfs /dev/sdb"; on windows, I bet it is even easier (right-click sort of menu item).
I hope this helps someone -- it really was an irritation when it happened to me just before a 15 hour drive.
RCA Lyra M2030... | Answered on Sep 03, 2008
one the file may be currupt, or ur memory is full
RCA Lyra M2030... | Answered on Jun 29, 2008
i recomend a San Disk card( they work great with this player)
ok... when your looking at it from the front (screen forward) on the right there are 4 buttons.. the top button is play/pause push that the turn on the mp3 player. underneath the play/pause button is the stop button this stops the song and when you hold the stop button down it turns off the mp3 player. the next buttons are the skip forward and skip backward buttons.. on the left side, the very top button the longer shaped one is the +/- volume button. underneath the +/- button is the equalizer button push this to changed the sound of the device.. and the last button i have yet to figure out.. i hope this helps you..
RCA Lyra M2030... | Answered on Apr 07, 2008
RCA Lyra M2030 MP3 Player Logo
30 questions posted
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
what the
  • Audio Players & Recorders
