20 Most Recent Meizu Mini Digital Media Player Questions & Answers
Perform a reset.
Meizu Mini... | Answered on Sep 01, 2017
I have the same problem and I don't know how to up grade my resorces om my meizi player
Meizu Mini... | Answered on Mar 26, 2013
ok, so u formatted your player, hence the green screen. So now all you have to do is download the firmware(match your player, sl with sl firmware, etc) then extract w/ winrar, u get 2 files so put them both in root folder (displaying music, video, etc) unplug turn off, on it will update then wait few min till it turns off, then turn on and ur player will work.
Meizu Mini... | Answered on May 23, 2012
If you have a Meizu M8 type of player you could get support via this link:
http://en.meizu.com/help/M8upgrade.html
On this site you can see detailed guide how to repair the device.
If you have not a M8 type, I am sorry and forget this advice.
gylacz
Meizu Mini... | Answered on Feb 14, 2011
Different MP3 players use different media formats, sounds like you need to convert the music files you have into a different type of file.
Check your owners manual to see what type media file your player has to have.
If it is different from the one you have, convert the files to work for your player.
Please Rate Me
You can download a FREE media converter here: http://www.formatoz.com/
Meizu Mini... | Answered on Dec 29, 2010
have you downloaded the driver .. from the meizu website?
Meizu Mini... | Answered on Nov 26, 2010
Your unit has undoubtably gone faulty.. Unfortuanately it's gonna have to go back to manufacturer/Suppier for repair replacement. This is a seemingly a very common problem.
Meizu Mini... | Answered on Aug 26, 2007
http://www.manualslib.com/manual/100994/Meizu-Electronic-Technology-Mz-03.html?page=6#manual
Meizu Audio... | Answered on Oct 30, 2013
Check the belt- if it is a belt drive turntable.
Audio Players &... | Answered 5 hours ago
Check your Ariel connections for corrosion (clean them all up)
Have you relocated the unit?
Have you placed/relocated any other electrical devises near it recently??
Audio Players &... | Answered 10 hours ago
Hello Dilum, make a test to control the sound level of the speakers connected to your harman kardon, you must press for more than two seconds the test key that is on the front panel, in the set of keys at the bottom
With the Test, you will be able to check the volume of each speaker individually, this is explained in the user manual on page 4 Item 9
If with the test, the level is fine, then you would have some problem in the recording or the program you are listening to
I hope I can solve the problem
Greetings Franco Dosil
Hola Dilum, haga una prueba para controlar el nivel se sonido de los parlantes conectados a su Harman Kardon, debe presionar por mas de dos segundos la tecla test que se encuentra en el panel frontal, en el conjunto de llaves en la parte inferior
Con el Test, va a poder chequear el volumen de cada parlante en forma individual, esto esta explicado en el manual de usuario en la pagina 4 Item 9
Si con el test, el nivel esta bien, entonces tendria algun problema en la grabacion o el programa que este escuchando
Espero pueda resolver el problema
Saludos Franco Dosil
https://data2.manualslib.com/pdf/7/658/65714-harmankardon/avr20ii.pdf?3e1777e124b0c9a1878f4d39601e577d&take=binary
Audio Players &... | Answered 13 hours ago
An internal fuse may have opened.
Audio Players &... | Answered 16 hours ago
Meizu Mini Digital Media Player Logo
Popular Tags
22 questions posted
Top Meizu Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Meizu Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Meizu Audio Players & Recorders
Most Popular Question
meizu mp4 player
  • Audio Players & Recorders
