20 Most Recent
Acer Aspire E1-531-4444 15.6" Notebook Computer Questions & Answers
Win 8 install error
Unless I've muisunderstood, the OP knows the drive was corrupted and was trying to reinstall when he/she get the IRQ_NOT_EQUAL error. This is either a dodgy optical drive, or an AHCI issue. Look in the BIOS under SATA mode and set it to AHCI. Failing that, try another DVD drive. If neither of those work then you'll have to replace your hard drive I fear.
How to reset acer
try installing a new os [win7 or win8] just make sure when you do dont delete hidden partition called pqservices if you do that u will brick your acer they r a mongrel for this type of crap if youve alrdy done it then you will have to contact acer
What to do if boot configuration data missing or contains errors appears on screen
This will depend on the exact error message. The course of action cannot be determined from your initial post. However, it may require you to set your BIOS/CMOS settings correctly, or more likely, Windows is damaged and you need to perform a recovery installation. If you wish to repair windows you will need to obtain a correct Disc for your version of Windows installed and try a repair. complexsystems.co.uk
Green screen
Sounds like your hard drive may be faulty. Run the manufacturers free hard drive diagnostic software (from CD or USB drive to test)
Update Installation of programs appears when
Hi,In this case it would be best to perform a system restore. There are two ways to perform system restore:Open start menu click run and then type cmd to open command prompt.Type CD.. to make c:\ only.Type CD windows then CD System32 and then restore.After once you find yourself in c:\ windows\system32\restore>Then type restrui.exe press enter.Once the system restore window open then click next to select any available restore point.This process shall take couple of minutes to perform restore and please make sure that once this process started it wont be reversible and neither you will lose any personal data.Other way to perform system restore is to open safe mode by clicking F8 on start-up and check safe mode option then further a dialogue box will open to ask for system restore and then follow the above steps. Thanks
