FixYa.com
Emerson 53861 Fan
All Products > Emerson > Electric Fans
Problems with Emerson 53861 Fan?
Search inside Emerson 53861 Fan Knowledgebase
Troubleshooting and Support
Solved Problems for Emerson 53861 Fan RSS Feed Post a New Problem
I removed the old fan & light. There...
I removed the old fan & light. There are 3 wires coming out of the ceiling - white, black & red. The wires...
1 Solution
I have a 36 inch ceiling fan with four...
I have a 36 inch ceiling fan with four wooden blades. The thing always ran with a little wobble, but after it was taken...
1 Solution
fan problem
whines when turned on. seems to be either a grinding or a off-balance of blade and shaft
1 Solution
Electrical Problem
installed a carriage house 2. Light kit works, fan does not. took apart, investigated... white electrical connector...
1 Solution
snowthrower won't stay running
when priming it leaks gas and hard to start and won't stay running
1 Solution
purchased a hap 726-on 2/7/08 holmes...
3 days later the unit is not working? i've checked to make sure everything is seeded properly, nothing. all light...
1 Solution
Casablanca W32 Fan and Light Switch...
I installed a new W32 wall controller for a Casablanca fan and the Fan and Light switches are reversed. When I swap the...
1 Solution
View All
Tips & Tricks
Post a New Tip
Emerson Contact Information
Main support number905-940-5089
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
