20 Most Recent
Hampton Bay 46175 Cameron II Plus Ceiling Fan Questions & Answers
Help with ceiling fan
black with black is for fan motor from swith red with red is for light fan from switch blue goes conect to black thats power for the remote white wuth white thats streat line is call comun or negative green withe green that streat conection for ground protection
Ceiling Fan wires
you don't have the necessary wires. you need to run a 3-wire cable (wht, blk, red, grd) between fan+switch. then post bac for instructions...
What kind of saf tbar and bracket for hampton bay 52 inch ceiling fan
Hampton Bay Ceiling Fans typically use a universal mounting system, which is compatible with most ceiling fan down rods and mounting brackets. If you have a 52 inch Hampton Bay Ceiling fan, you can use any standard mounting bracket and support bar (also known as a "J-Hook" or "Safety T-Bar") that is rated for ceiling fans up to the same weight and size. The weight of your specific fan should be listed in the product manual or on the manufacturer's website.
It's always a good idea to double-check the compatibility of any mounting hardware with your fan before purchasing, to ensure that it will provide a secure and stable installation.
