20 Most Recent
Stanley 5 Watt Led Waterproof Rechargeable Spotlight Camping Hiking Flashlight Questions & Answers
How do I switch from strobe to constant light?
Depress the switch until light goes on but does not click on and then release just a little and depress again, light should switch to solid if it does than depress button all the way until it clicks on. If there is a high and low setting on the torch than make sure you are in high.
Stanley ultra bright led spotlight SL5W09L will
I am having the same problem with one of mine. If I turn it down to low it will stay on. (press and hold the down arrow on the back of the light after you turn it on till it beeps, then it works forever).
How do I get my Stanley 2m series spotlight to Charge?
To take the charge the inbuilt battery must be functional. Once the battery goes bad you will be unable to charge the unit or it will take a small charge and die rapidly thereafter.
You may or may not be able to change the battery. It depends on the manufacturer of the product so you should consult the instructions that came with the item if you still have them.
Need a replacement charger & instruction
I need a replacement cord to recharge my Stanley Bar Flex, Model #BF0109S, 6Vote DC-600mA. Is this something I can purchase from you? I can be reached at 207-395-4721 or you can email me at:
[email protected] you for your prompt attention.Jane W PerkinsEast Winthrop, ME 04343-0373
