20 Most Recent Gateway 835GM (835GH) PC Desktop Questions & Answers
I have a old Gateway 835gm that im trying to revive with a XFX R7 250 Graphics Card Unfortunatly, Whenever i start it up, The Gateway logo flashes for about half a second, and i get no signal.. Help?
Do you hear any beeps when the computer is turned on? How many do you hear and what sequence? Have you tried to put the computer in the hardware setup mode? Perhaps it is done by holding down Ctrl/F2 keys while turning on the computer. What are the settings for the hard drive and monitor found in the setup mode? Do you have another graphics card to try out in this computer? Try it and report back.
7/22/2015 4:57:53 PM • Gateway 835GM... • Answered on Jul 22, 2015
I need a new graphics card - are they still
8641107c-41fb-47e8-abd9-242eb2eb8bb3.jpghttps://support.gateway.com/s/PC/R/5022/5022sp3.shtmlgateway support shows you have a pci-e x16 slot for a video cardyou can choose a non-powered pci-e video card for your system, which might be better for you if you still have the stock power supply in your tower.or, you can choose a powered pci-e card if your power supply is powerful enough to run your system AND a pci-e video card too. a powered card will have a spot for a 6 pin (or 2x 6 pin or sometimes a 6 pin and/or an 8 pin) power connector that comes from your power supply to the video card ... you may have to replace your power supply to use a powered card, or get a pci-e power adapter (not the preferred method, but sometimes works).here is an example of a non powered pci-e card4be000da-0366-469d-a4e5-7e856ed11d23.jpgand here is an example of a powered pci-e card, see that black connector near the back of the card, that's the power connectiond14f2193-6517-4757-bb64-295e7b40c008.jpgand the 6 pin connector from the power supply looks like this (and power supply adapter shown also)354f29da-d560-40ae-ba05-463a627b8eb0.jpgdoes this help?
8/27/2013 3:46:30 PM • Gateway 835GM... • Answered on Aug 27, 2013
Sound driver
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers If your computer came with a motherboard disk the drivers could be on it or you might download slimdrivers. Rather doing a driver hunt http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 Note: it will find all of your outdated drivers This is a free driver solutions which will automatically search for and find the correct driver You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. It might take some time being free also http://download.cnet.com/2000-20_4.html Just type in what you want or need be specific you might have to try a few times to get it right. Tick in either the all software or the windows software box. IE: motherboard name sound drivers http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html Windows XP/2003/Vista/Server 2008/7/8 free drivers http://download.cnet.com/drivermax/3000-18513_4-10572602.html Windows 2000/XP/Vista/7/8 free driver program Hope it helps.
12/28/2012 9:45:51 PM • Gateway 835GM... • Answered on Dec 28, 2012
Integrated 10/100/1000 Network Card drivers
Get onlineand got to www.google.com In the google search box type: "GatewaySupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Network drivers.
4/27/2012 2:21:03 PM • Gateway 835GM... • Answered on Apr 27, 2012
I made some mods/upgrades for Gateway 835 GM (Started with RAM -2GB Sticks- , Video Cards, & Finally CPU because of the sudden not wanting to display anything on my screen! PLEASE READ & REVIE
Here is what I would do, depending on your board go to what the brand is and download the BIOS again flash it if you do not see the BIOS at the startup. If you do see the BIOS then you will need to install the drivers for these components you replaced. Depending on which operating system you are using. Win XP you will have to load drivers from the driver disks that came with the product replacement or search for one online. If you have Win 7 it should pick the drivers up through Windows Updates load them without them or a running BIOS your shot in the dark. Your computer has to have a BIOS and drivers to run the hardware you replaced. Just because you had them before does not mean it will operate. correctly. Make sure your components are the correct ones for your machine. Just because ram fits does not mean it is the correct ram. So get BIOS up again from there boot from C: reload Windows then re install the whole operating system and be sure to load drivers and updates. That is how I would proceed with this issue. John
4/9/2012 12:13:58 AM • Gateway 835GM... • Answered on Apr 09, 2012
Why are the fans so noisey
You used word FANS so seems you have two - probably one on processor and one on case. Unplug power cord, remove case cover and inspect for debris. Blow out gently with canned air if dirty. Retry. If still noisy, disconnect power cable to one fan and retry to see which one is making the noise. Then remove bad fan and take it and data on the computer make/model to a computer supply store and buy a new fan. Check that the hole pattern and power connector are the same. Take home and reinstall. Problem fixed for about $20.
2/20/2012 7:27:32 PM • Gateway 835GM... • Answered on Feb 20, 2012
Need help with my gateway 835gm replaced memory ram
Does your motherboad support the ram and is it the same as the other one (if any)
2/2/2012 7:32:58 AM • Gateway 835GM... • Answered on Feb 02, 2012
Removed dd card to check it i reinstalled my gateway 835gm it turns on it reads log on to windows click ok but it wont do any thing
Either the RAM module has not been installed properly or the RAM is faulty. Try removing the RAM module and inserting it again, make sure the locking levers on the ends of the RAM modules are locked in place.
1/30/2012 6:05:09 AM • Gateway 835GM... • Answered on Jan 30, 2012
Replaced my hard drive on
Have you reinstalled the video driver after you have reinstalled Windows? If not get it from the official page
http://support.gateway.com/us/en/product/default.aspx?partNumber=5022
8/15/2011 2:53:17 PM • Gateway 835GM... • Answered on Aug 15, 2011
My monitor would not come on after a thunder
do you have a surge protector? if not then you probably popped the little fuses in the back of the monitor, at the very least.. you could have blown a diode as well, as far as the comp, see if it has a fuse, it should be close to where the power comes into the machine
9/12/2010 7:35:07 PM • Gateway 835GM... • Answered on Sep 12, 2010
0answers
835gm powers up, but monitor power button goes
1. It could be bad connection of Memory, CPU, Graphic-cards etc. Try to reseat them aswell.
2. Have you tried replacing the power-unit?
3. Some BIOS es are a bit 'stupid', do you have a fairly new and working monitor plugged in directly (bypassing KVMs)?
Worst case is 'BGA-slip', the bridge-chips and/or onboard GPU has some broken solderings, typically happens to Laptops.
7/18/2010 3:53:16 PM • Gateway 835GM... • Answered on Jul 18, 2010
Wont turn on
Check the Power supply. It's in the back. Use your nose, it it smells like burned wiring, change it. You can buy a 450 or 500 for around $40.00.
Good Luck
7/11/2010 4:29:00 PM • Gateway 835GM... • Answered on Jul 11, 2010
HTLDR is missing
It's NTLDR. Your system is unable to boot your operating system. now do this following steps:
1. Insert the Windows CD and start the computer.
2. When the Welcome to Setup screen appears,           press R.
3. Type a number corresponding to the Windows           installation you wish to repair (usually 1) and press     Enter.
4. When prompted, type the administrator password       and press Enter.
5.  From the command prompt, copy NTLDR and            NTDETECT.COM from the i386 folder of the CD to      the root folder of the hard drive. In the example          commands given below, C: is the hard drive and        D: is the CD-ROM drive. You will need to change        the drive letters if appropriate:
     COPY D:\I386\NTLDR C:\
     COPY D:\I386\NTDETECT.COM C:\
6.  Remove the Windows XP CD from the drive and          restart the computer.
6/8/2010 9:19:06 AM • Gateway 835GM... • Answered on Jun 08, 2010
Installed windows 7 on my
You can try running "Startup Repair" from the Windows 7 DVD. It should reinstall the kernel designed for the non-ACPI PC. If that does not work, try and set the BIOS back to it's previous state by using the original operating system CD your Gateway 835Gm came with from the factory.
5/30/2010 3:57:28 AM • Gateway 835GM... • Answered on May 30, 2010
I just purchased a refurbished Gateway 835 Gm
Well youve paid for and got it know, so it shouldn't really matter. I think once you have something then you should not worry about the cost unless it starts giving hassle. I bought my PS3 and a few weeks later it dropped by 150€, but I have it and Im happy with it.
2/17/2010 11:07:01 PM • Gateway 835GM... • Answered on Feb 17, 2010
I lost the BIOS Password, how can I retrieve
you will have to open up the side of the pc and take out a battery the size of a 25cent called the cmos battery and then start the pc without it wait for a minute or two then shut it down and put it back it in
2/10/2010 9:11:42 PM • Gateway 835GM... • Answered on Feb 10, 2010
Gateway 835GM (835GH) PC Desktop Logo
50 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
need new graphics card still
  • Computers & Internet
