20 Most Recent
Acer Aspire T650 PC Desktop Questions & Answers
Yes, I did make sure that I set my CMOS setting to
Sounds like the boot sector on you HDD is corrupt, so it can't read it. Try using a repair tool you can run from a CD or USB stick. You will have to get it setup on another computer, then run it on this one. There ae quite a few of these programs available for various systems. Check the link:
https://www.google.ca/?gfe_rd=cr&ei=Z862VL_KJ8Gy8wfizYCQBw#q=boot+sector+repair+tool
Need Lan driver for Acer Aspire T650, Motherboard ERC410M.
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
click start control panel administrive tools computer management device manager scroll to network adapters could see a yellow question / exclamation mark? ! or a red X right click install drivers
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimake sure its enabledPci device arrows key scroll to nstalled.
http://download.cnet.com/lan-driver-nvidia-ver/3000-2112_4-162233.htmlhttp://download.cnet.com/atheros-ar8121-ar8113-pci/3000-2112_4-191674.htmlhope this helps
Any audio driver for windows 7?
That's the problem with windows 7, not all drivers are available. Try
the Vista Drivers. Most times if windows 7 drivers are not available,
the vista drivers will work.
Get online
and got to www.google.com In the google search box type: "Acer
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Download and install the Audio drivers.
Try using the VLC Player. It comes with drivers and codec. I've seen it solve many sound and audio issues.
Try using VLC as your player. Go to www.google.com and
in the search box type "download vlc" (without the quotes).
Look for the Video Lan download from site www.videolan.org/vlc Download
and install it. It downloads and installs in 3 minutes or so. It's
a very fast player, smooth and it can play just about any type of dvd formats
and media. It's totally FREE.
DRIVER ASPIRE T650 WINDOWS 7
If you were to log on to the acer.com web site, I think you may be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers for spare part supplies and
Driver
downloads
(if applicable)
as required.
The information is normally free of
charge.
I hope this helps.
Error 720 - the connection attempt failed because
To resolve this behavior, follow these steps:
- Find out which protocols the RAS server is running, and make sure that the RAS service is installed and configured properly (or ask the Network Administrator to do this).
- After you find out which protocols the RAS server is running, make sure that your Windows XP-based computer is running one of the same protocols that the RAS server is running:
- Click Start, click Control Panel, and then double-click Network Connections.
- Under Virtual Private Network, right-click the VPN connection, and then click Properties.
- In the VPN Connection Properties dialog box, click the Networking tab, and make sure that you have a protocol that the RAS server is running.
- If you do not have a protocol that the RAS server is running, add the needed protocol:
- Click Install, click Protocol, and then click Add.
- Click the protocol that you need to install, and then click OK.
- Click Close in the VPN Connection Properties dialog box.
Dial up connection ends in error code 720, can't
because your computer and the remote computer could not agree on PPP control
protocol.
To resolve this issue, uninstall the TCP/IP protocol, remove
the second WAN Miniport IP device, and then reinstall the TCP/IP protocol. To
do so, follow these steps:
- Uninstall the TCP/IP protocol. To do so:
- In Control Panel, double-click Network and
Dial-up Connections, right-click Local Area
Connection, and then click Properties.
- Under Components checked are used by this
connection, click Internet Protocol (TCP/IP), and
then click Uninstall.
- Follow the on-screen instructions to uninstall
TCP/IP.
- Restart the computer when prompted, but click
No if you are prompted to allow Windows to enable a
protocol.
- Right-click My Computer, and then click
Properties.
- Click the Hardware tab, and then click
Device Manager.
- On the View menu, click Show
hidden devices.
- Under Network adapters, there should be no
WAN Miniport IP devices. If a WAN Miniport IP device is listed, continue to the
following step. If no WAN Miniport IP device is listed, go directly to step 16.
- Click Start, click Run,
type regedit in the Open box, and then
click OK.
- Locate the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E972-E325-11CE-BFC1-08002BE10318}
- On the Registry menu, click Export
Registry File, type backup-key in the
File name box, and then click Save.
Note You can restore the changes that you make to this registry key.
To do so, double-click the backup-key.reg file that you saved.
- Click each of the registry subkeys under this key, and then
view the Data column of the DriverDesc value
to determine which of the subkeys corresponds to WAN Miniport (IP). For example, the 0005 subkey.
- Right-click the subkey whose DriverDesc
value data is WAN Miniport (IP) (for example, right-click 0005), and then click
Delete. Click Yes to confirm that you want to
delete the key.
- Quit Registry Editor.
Properties.
Device Manager.
hidden devices.
- Under Network adapters, right-click
WAN Miniport (IP) and then click Uninstall.
Click OK to confirm that you want to remove this
device.
- Reinstall the TCP/IP protocol. To do so:
- Click Install.
- In the Select Network Component Type
dialog box, click Protocol, and then click
Add.
- Under Network Protocol, click
Internet Protocol (TCP/IP), and then click
OK.
- When the protocol is installed, click
Close.
- Reset the modem by turning the power off and then on, or
for an internal modem, restart the computer.
- Test your Internet connectivity.
When I log on I am getting a message
your pc maybe overload of installing programs. if some program not working it's currupted with virus so that some massage pop-up on your desktop or try to check your memory (RAM) because so many programs installed, your RAM can't handle does program>>. solution: upgrade your RAM and clean up your pc with updated anti virus... if you're aware of COMBOFIX software, clean your pc with COMBOFIX. using that software (COMBOFIX) all autorun viruses will be delete...!
No sound from board
Try running DxDiag.exe. It comes for free when you install DirectX (which is also free), and it has a lot of good built-in diagnostics. It tests several types of sound files to narrow down the problem.
Access outlook
what password computer or outlook
Reset an Outlook password to keep your program secure.
A
Microsoft Outlook password keeps your email account secure from unwanted
intrusion.
When you wish to reset your Outlook password, you must
perform a multistep process to change your password first with your Internet
Service Provider (ISP).
The password with your ISP mail server must be the same as
the password you set in your Outlook program in order to send and receive
emails.
Call your ISP and request a new password for your account.
Write down the password after you receive it to ensure you
do not forget it.
Open your Outlook program, click the "Tools" tab
and then select "Email accounts."
Select "View or change existing email accounts"
and then press "Next."
Highlight the email account you wish to change (if you
have more than one email account) and press "Change."
Enter the new password you just received from your ISP
into the appropriate fields (entering it twice).
Place a check mark beside "remember password" if
you want Outlook to remember your password each time you log in.
Click "Test Account Settings" to make sure your
account works with the new password.
Press "Finish."
I forgot my Outlook password
http://office.microsoft.com/en-us/outlook-help/i-forgot-my-outlook-password-HA001113690.aspx
Acer Aspire E1 571 not charging battery.
Question edited for clarity and toss in a few CAPS.
Question moved to Acer Aspire category.
There a few issues that can cause this, the obvious one is that the battery has failed internally, but it can also be a charging software issue. Try this. Unplug from the mains supply. Remove the battery. Leave the computer for 2 hours. Press and hold the power button for a full 2 minutes. Replace the battery, plug back in, count to 10 and power it back up.
Has the motherboard battery ever been changed? They are critical to the health of the motherboard and the machine in general.
Aspire E1-571 Plugged in not charging
Acer Community
https://community.acer.com > ... > 2016 Archives
Aug 20, 2016 - Hi, I have been having a quite critical issue with my laptop recently.
Acer Plugged In Not Charging
Driver Easy
https://www.drivereasy.com > ... > Common Errors
Apr 21, 2021 - This plugged in not charging problem may occur if you are using the wrong battery driver or it's out of date. So you should update your battery ...
Acer E1-571, Charging problem
Tom's Guide Forum
https://forums.tomsguide.com > threads > acer-e1-571...
Feb 10, 2019 - Hi there, I have a acer e571 laptop and i am facing a battery charging problem, whenever i plug in charger it start charging for 10 to 15 seconds and start.
1 answer ยท Top answer: It could also be the charger. The fact that moving the cord made a difference makes me think it might be. Also, have you tried charging it when the laptop ...
My acer e1 570 laptop won't charge - Tom's Guide Forum
Feb 7, 2017
I have an Acer Aspire E1-571-6837. It will not charge the ...
Aug 25, 2016
Hi my acer aspire E1-571 won't turn on. I plugged it in and it ...
Mar 9, 2018
More results from forums.tomsguide.com
