20 Most Recent
PPI PC2600 Car Audio Amplifier Questions & Answers
I just replaced an amp and now the inline fuse by
Most likely you have your power and ground connections reversed on the amp. That will cause the fuse to blow immediately upon contacting the two sides of the fuse. If the fuse stays intact for a short while but pops after turning the amp/car on and your connections are correct then there's a problem with the amplifier and it either needs to be serviced or replaced.
Need owners manual
Here is an archive of PPI PowerClass amp manuals...
http://narbi.free.fr/manuels/Amplis/Precision%20Power/Serie%20Powerclass/
Ppi amp
Here is an archive od PPI PowerClass manuals...
Need lost power pluggs
both the power and speaker plugs are available on e-bay. search for ppi plug(s). You will find them there. Also, if you are interested in the actual maker of the plugs, I believe it's a company called WECO.
Ppi pc2600
If the fuse only blows after the remote voltage is applied, the output transistors are likely shorted. To eliminate the speakers as a possible fault, disconnect the speaker wires from the amp. Also disconnect the signal cables.
If the fuse blows without remote voltage applied, either the power supply transistors are blown or the B+ and ground are reversed (or they may have previously been reversed).
I NEED A INSTALL AND
Hi and welcome to FixYa,
The installation and user's manual for the PCX series 4 Ch of Precision Power mobile amplifier including the PCX4125 is available
here.
Good luck and thank you for asking FixYa.
