20 Most Recent
PPI PCX-280 Car Audio Amplifier Questions & Answers
Need to know how to
If you look at the speaker hookup it will say bridged and have a line going to the two that you should use....If it doesnt then it might be an amp that you cant bridge
PPI AMPLIFIER NO SOUND PSX-280
make sure the remote wire from the deck is in the amp but move your ground wire to a new solid metal location you may have to scrape the paint surface where the ground is going to go but it will stop protect mode and run properly (make sure to bolt it down by its self no other wires just the ground from amp) also make sure the ground wire is bigger than the power wire
hope this helped
RODEK AMP PROTECTION
have you checked your speaker connections and any other connection for shorts or multiple ground loops. cause that will definately cause the protection mode.
I NEED A INSTALL AND
Hi and welcome to FixYa,
The installation and user's manual for the PCX series 4 Ch of Precision Power mobile amplifier including the PCX4125 is available
here.
Good luck and thank you for asking FixYa.
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
