20 Most Recent Dell Dimension E521 (D10E16) PC Desktop Questions & Answers
have you tried booting in safe mode?if not try it first.
if you have successfully loged in safe mode. Try using the system restore to restore the system.
if you still have blue screens. do the following.
first try removing the video card and the memory card.
Clean the gold bars using a white eraser.
after cleaning put them back and make sure they are properly inserted in their slots.
Turn on the computer, if the problem still occurs try removing your cd rom drive.
Turn on the computer if the problem still occurs that means your operating system is corrupted or you have a broken harddisk.
Try reinstalling a new operating system. If you have so many important datas in your hard drive I suggest you use Windows 7 cause you can install without reformatting your hard drive.
Here is a video tutorial on how to install windows 7 without restarting.
If a problem occurs during installation it means you have a broken hard drive you have to replace it.
Goodluck, please give me updates if you have any success. THANKS.
Dell Dimension... | Answered on Mar 10, 2019
search google 'find my ip'
Dell Dimension... | Answered on Mar 06, 2014
Check if there's like weird noises coming from the dvd drive (while you have a disc inside). You may also visit support.microsoft.com. You can also google how to delete upper and lower filters through regedit.
Dell Dimension... | Answered on Oct 24, 2013
Kindly check Device Manager if the driver has been successfully installed. Check if there is a bang (exclamation mark) under Network. Make sure that the downloaded driver is compatible with Windows 7. If this has been done, 1. Go to BIOS and see if LAN has been disabled 2. check if there is a blinking light on the LAN port on your computer. If there isn't, then I guess you may need to change your LAN card.
The BIOS information is typically found at or near the top of the POST screen for a very short time ALR PC non / PCI = CTRL+ALT+ESC AMD advanced micro devices=BIOS = DEL Award BIOS = DEL Dtk Datatech Enterprises Co. BIOS = ESC Phoenix BIOS = CTRL+ALT+S Phoenix BIOS = CTRL+ALT+INS Restart your computer during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have Press and hold that key during the boot up process to enter BIOS if you have changed any of the BIOS settings by mistake you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer.. this will reset your cmos
Dell Dimension... | Answered on Feb 28, 2013
you might try another keyoard to see if it works
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
make sure ps2 or the usb lead has a secure dust free connection if applicable
disconnect the keyboard restart your computer then reconnect it the found new hardware wizard should activate
if this does not fix the problem
restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode
Click start control panel keyboard hardware make sure you have the right keyboard selected
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
hope it helps
Dell Dimension... | Answered on Jul 19, 2012
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure dust free connections and are not faulty or just replace them they could be faulty a computer needs power and data to travel through every
working device and to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty power lead or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
make sure the CPU central processing unit has a dust free secure seating
you can usually do this by pressing the levers down at both ends of the CPU
hope this helps
Dell Dimension... | Answered on Jul 09, 2012
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Dell Dimension... | Answered on Jun 03, 2012
Its all because virus try to install a latest antivirus in this & scan ur computer it will solve ur problem
Dell Dimension... | Answered on Apr 11, 2012
Nope. you cannot access your files. even if you use a external hard dive to access the files.
i suggest you install windows 7 in your computer but do not reformat the hard disk . in that way your files will still be saved in your harddrive.
Once you have access to your files i suggest you save them in a flash drive or external hard drive if you have one. then reformat your computer and install a windows xp.
here is a tutorial on how to install windows 7 without reformatting your harddrive.
Goodluck. If you have any success using my solution please give me updates.. Thanks
Dell Dimension... | Answered on Jun 29, 2011
Have you checked if you are connected to internet?
Go to start then CONTROL PANEL then NETWORK CONNECTIONS
There you should see if you are connected.
If your Lan/WLan is connected try this.
  1. Right Click the LAN/WLAN that is connected to the internet, then on the menu choose properties
  2. Now on the window choose INTERNET TCP/IP then click heifentrixx_3.jpg like in the photo.
  3. On the next window choose OBTAIN IP ADDRESS AUTOMATICALLY and OBTAIN DNS SERVER AUTOMATICALLY like in this photo. heifentrixx_4.jpg
  4. Click ok then try connecting to your internet. but i suggest you restart you computer first.
Goodluck.. Please give me updates if you have any success thanks.
Reinstall video driver. Download and install VLC media player and K-Lite Codec. Both are free downloads and you can easily find the download links by doing a google search.
Dell Dimension... | Answered on Apr 17, 2011
In motherboard, there is a reset Jumper . Check from the manual.
Dell Dimension... | Answered on Apr 06, 2011
There is no other way to power up the computer. The green light inside the pc don't mean it is on, it can be only the network card led (that is always on). I suspect a defective unit. Try holding the power button for some seconds if it's booting up.
Dell Dimension... | Answered on Mar 01, 2011
Assuming that the power supply that was replaced was the proper wattage and physical size, go ahead and disconnect all of the plugs, boards, memory chips and anything else that is connected to the motherboard. Connect only the power connector main and the cable that allows you to power the system off and on, then press the power button. You should get a beep-code from the mother board telling you that there is no memory onboard (make sure there is a speaker either attached to the motherboard or connected to it via the speaker connector.) If you get no beep, the motherboard is probably bad and will need to be replaced. If you get a beep, start connecting items one-by-one until you find the one that won't let the system power up, that's your bad part.. Good luck and I hope this helps.
Dell Dimension... | Answered on Feb 10, 2011
If the new formatted system works fine you need to reconfigure your network. More info please!
Dell Dimension... | Answered on Oct 19, 2010
YOU will need additional sound cable
Dell Dimension... | Answered on Oct 16, 2010
Try using the safe mode or debugging mode
when windows starts press F8 the select the mode
Dell Dimension... | Answered on Aug 31, 2010
Dell Dimension E521 (D10E16) PC Desktop Logo
47 questions posted
Clive
Clive
Alun Cox
View Most Popular
Dimension Dell
  • Dimension Dell
Most Popular Question
dell dimension e521 wont boot windows
  • Computers & Internet
