FixYa.com
Tec Cherokee Gas Grill
All Products > Tec > Grills and Smokers
Problems with Tec Cherokee Gas Grill?
Search inside Tec Cherokee Gas Grill Knowledgebase
Troubleshooting and Support
Solved Problems for Tec Cherokee Gas Grill RSS Feed Post a New Problem
Propane Regulator Adjustment
I have a Marshall Gas Controls propane regulator Model 230 installed on a sailboat and I need to increase the discharge...
2 Solutions
jenn air 32 in. 4 burner gas grill
I put a replacement propane tank on and the burner lights for about 2 seconds then goes out. It does the same when I try...
1 Solution
b.q.grill
can a natrual gas grill be use with propane gas
1 Solution
weber charcoal grill repair
The flanges that close the vents on my platinum one touch weber grill have bent, and no longer close the vents. I am...
1 Solution
gas line and codes
I have a natural gas grill. I want to run a gas line from the meter to the grill. Does the gas line need to be buried or...
1 Solution
Fire Magic won't lite
2 weeks ago I installed a 36" Fire Magic Echelon with a searing station. It is difficult to lit and sometimes wno't...
2 Solutions
jenn-air grill
I just bought this grill----Jenn_Air Model No-720-0336 and the rotisserie burner keeps going out after it gets hot.
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeGrill
Fuel TypeLiquid Propane
Cooking Area167 sq. in.
Top LidWith Lid / Top Hood
Ignition TypePush-button igniter
Burners1 Burners
Other Features
BTU'S per hour14,000 BTU
Cooking GridsStainless Steel Cooking Grids
WheeledNo Wheels
Dimensions
Depth16 in.
Height11.25 in.
Width15.25 in.
Warranty
Warranty5 Years
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
