20 Most Recent Epson Stylus DX6050 All-In-One InkJet Printer Questions & Answers
13 Watts is highest power draw.
Epson Stylus... | Answered on Nov 06, 2015
The error code E-90 appears when the print head is not able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the printer
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the printer back on.
- or, If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  4. Close the scanner.
  5. Turn the printer back on
epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-0.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-2.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-5.jpg
Epson Stylus... | Answered on Dec 08, 2014
Hello there friend, Not an expert on Printers but....
Apperently so !!!! Threr at least three on the power input side.
The absolutely FANTASTIC Full service Manual is downloadble as a
PDF for FREE here http://elektrotanya.com/epson_stylus_cx4900_cx4905_cx5000_cx5900_cx6000_dx5000_dx5050_dx6000_dx6050_sm.pdf/download.html
Just below the preview you will see the tiny download word.
The fuses are in the Appendix Electrical circuit sections.
The manual guides you through ALL faults if no power on.
Epson Stylus... | Answered on Sep 10, 2014
Does the outlet you are using have power?
Epson Stylus... | Answered on Aug 15, 2014
This could happen from a variety of different reasons, but usually it is a temporary glitch between the printer and the computer.
First, try powering down the printer, then turn it back on, and try again.
Next, try rebooting your computer, then try again.
If you still have trouble, then print a test page. You can do this by following the directions in the printer's owner's manual, or from selecting Start / Control Panel from your Main Menu, then clicking on the Printers icon. Follow the directions from there. If that works, then the file you are trying to print is probably corrupted. Try to re-save it under a different file name and then attempt to print again.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Epson Stylus... | Answered on Jun 25, 2014
no ink
Epson Stylus... | Answered on May 23, 2014
Hope this will help.
To check the ink cartridge status, do one of the following:
  • Double-click the printer shortcut icon on your Windows taskbar. To add a shortcut icon to the taskbar,
    Open the printer driver, click the Maintenance tab, then click the EPSON Status Monitor 3button.
Good luck.
You must first do the setup with the included USB cable to register the printer on your network. Then you can add printer to your laptop.
Epson Stylus... | Answered on Apr 22, 2013
Epson Stylus DX6050 All-In-One InkJet Printer Logo
164 questions posted
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Stylus Epson
  • Stylus Epson
Most Popular Question
printer4 shows error e 90
  • Office Equipment & Supplies
