20 Most Recent
Laser Jet P3005 series Printer Questions & Answers
10.00.00 supply memory error
Memory Supply Error 10.00.00 The printer is unable to read or write to the print
cartridge e-label, or the e-label is not on the cartridge.
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on the front right of the toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector J510 on the ECU. You might have to remove the main cooling fan.
Contact a local HP Authorized Service Center for further assistance.
Which is best laser pointer for presentation ?
I agreed with Nancy. I was also reading reviews on https://reviewspack.com/best-presentation-clickers/ and https://www.thedailytell.com/best-laser-pointers-for-presentations/ Logitech Spotlight is most powerful pointer the R800
How i can resolve fuser error laser jet pro 400
A fuser error is probably caused by a thermistor (detects an overheating problem). The fuser is probably best serviced by the manufacturer as an improperly serviced fuser could lead to a fire.
Scanner error 6 in laser jet 3052
"Error 6" indicates a common problem with LaserJet, a brand of dry electrophotographic laser printers from computer technology company Hewlett-Packard. One of such machines is the HP LaserJet 3390, an all-in-one printer that can print, copy, scan and fax documents.
Hi dear experts ,hp color laser printer cp1215 is out of calibrate.What can I do to solve this problem ? Thanks .
- to recalibrate: first open Toolbox.
- For Windows XP:
- Click Start (), click All Programs, click HP, click your product, and then click HP Color LaserJet CP1210 Series Toolbox.
- OR in Windows Vista:
- Click the Windows icon (), click All Programs, click HP, click your product, and then click HP Color LaserJet CP1210 Series Toolbox.
- Click the Device Settings folder, and then click the Print Quality page.
- Under Print Quality, click Calibrate next to Calibrate Now.
- Click OK when the 'Your request has been sent to the device' message appears on the computer. The calibration process begins.
NOTE:
Calibration might take 2 to 3 minutes. Do not turn the product off during calibration.
- When calibration ends, try printing again. If the issue is resolved, stop troubleshooting.
- If you are still experiencing print quality issues, repeat steps 1 through 5 in this solution. You can recalibrate the printer as many as 3 times.
